Block Options: D16z6 or D16y7
Old Nov 26, 2003 | 11:06 PM
Simple's Avatar
Default Block Options: D16z6 or D16y7
Well, it comes down to this. I've got 2 blocks.
D16z6 100k
D16y7 40k
I'm going to be using a nu-forms block-gaurd, and endyne block pins to support the cyl. walls for boost (10-12 psi daily, 15 or 16 at the track). I dont think there is much difference in the two blocks, other than the engine code, and where the oil dipstick is located. ONLY going to be using the BLOCK for a complete Turbo re-build. head is also being re-built for turbo, and will be placed atop the winning block.
Opinions?
Old Nov 27, 2003 | 07:18 AM
RyanEJ8's Avatar
Default Re: Block Options: D16z6 or D16y7 (Simple)
If it the shortblock is being rebuilt for turbo, it doesn't matter. Just go with the one that looks cleaner.
Old Nov 27, 2003 | 07:33 AM
Ricey McRicerton's Avatar
Default Re: Block Options: D16z6 or D16y7 (RyanCivic2000)
I'd get the y7 because of the lower miles. Same basic block.
Old Nov 27, 2003 | 10:45 AM
beerbongskickass's Avatar
Lower mile one I guess. I got a question though... why are you posting the block and using a blockguard? Just posting the block should be all you need.
Old Nov 27, 2003 | 01:39 PM
Kelly.'s Avatar
I've quit using this account
wouldnt the z6 (with oil squirters) be better?
just a thought..
Old Nov 27, 2003 | 01:50 PM
RyanEJ8's Avatar
Default Re: (llewsirc)
Z6 doesn't have oil squirters.
Old Nov 27, 2003 | 02:56 PM
Simple's Avatar
Default Re: Block Options: D16z6 or D16y7 (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Lower mile one I guess. I got a question though... why are you posting the block and using a blockguard? Just posting the block should be all you need.</TD></TR></TABLE>
extra protection, got it cheap... wanting to boost 12 psi daily.
Old Nov 27, 2003 | 03:43 PM
SPOON_BeIgHtEeNsEe's Avatar
so a z6 and y7 block are the same??? with a full rebuild?
Old Nov 27, 2003 | 04:23 PM
Simple's Avatar
Default Re: Block Options: D16z6 or D16y7 (SPOON_BeIgHtEeNsEe)
i cracked open the D16z6 about 15 min ago.. bunch of carbon and crap inside the block, oil is all fudged around... looks like ill be using the y7 block, since they are the same. Ill just use the z6 head on the y7 and have a Turbo mini-me
Old Nov 27, 2003 | 04:34 PM
delpoop!'s Avatar
eww thats gross good luck with the mini me
Old Nov 27, 2003 | 11:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple &raquo;</TD></TR><TR><TD CLASS="quote">
extra protection, got it cheap... wanting to boost 12 psi daily.</TD></TR></TABLE>
Posting is all the extra protection you need. Even though you got the block guard cheap why would you risk it? Sorry to preach, but I have heard and read so many bad things about them I would never think of putting one in my car. Even if installed properly and if your lucky enough not to have coling problems I still don't think they are worth it. Post the block, tune it well, and you should be fine.
Old Nov 28, 2003 | 07:18 AM
RyanEJ8's Avatar
I don't have any bad things to say about a block guard.
Old Nov 28, 2003 | 07:35 AM
Civic TSI's Avatar
Been boosting 15psi for the past 5 years on stock sleeves and block guard with no problems. Boosted 19psi mostly the entire summer, no problems. Boosted 20-22 at the track, no problems. WG hose unpluged, boost went to 25-28psi, still no problems. Compression read 190 on all 4 cylinders.
Old Nov 28, 2003 | 10:32 AM
Default Re: Block Options: D16z6 or D16y7 (Civic TSI)
whats ur set up?
Old Nov 28, 2003 | 12:21 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I don't have any bad things to say about a block guard.
My old block overheated really bad with a block gaurd. Although mine wasnt that newer deisgns like that one you have. Mine had small holes drilled in it and it was solid from cyl to block. It overheated easy in hot weather.
liam
Old Nov 28, 2003 | 12:50 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">whats ur set up?</TD></TR></TABLE>
Old Nov 28, 2003 | 12:55 PM
biassj's Avatar
The D16y7 has diffrent pistons don't they? If you put the vtec head on the Y7, it wil yeild a high compression ratio which causes detonation.
edit.
Never mind, your going to rebuild the block with internals and others right.
Old Nov 28, 2003 | 01:23 PM
RyanEJ8's Avatar
Default Re: Block Options: D16z6 or D16y7 (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
I've never had an overheating problem and the weather here is hot all the time in Tampa.
Old Nov 28, 2003 | 03:38 PM
Simple's Avatar
i think ill use the supra piston, B16 rod combo that turbo panda offers.... so yea.. this autta be interesting
Old Nov 28, 2003 | 04:21 PM
sleepyhamsterlx's Avatar
well, back to the orginal question, go w/the y7 because of its miles.
Old Nov 28, 2003 | 06:42 PM
spraa's Avatar
From: Henderson/ College Station, Texas, United States
your going to build it?
Old Nov 28, 2003 | 07:10 PM
Simple's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple &raquo;</TD></TR><TR><TD CLASS="quote"> ONLY going to be using the BLOCK for a complete Turbo re-build.</TD></TR></TABLE>
better?
Jdm90hondacrx
Nov 26, 2017 06:07 PM
Jdm90hondacrx
Nov 1, 2017 10:29 PM
lilo_heu
Jan 27, 2008 06:58 AM
mugenkilla899
Nov 10, 2006 01:06 PM
Hybrid
Oct 14, 2002 06:02 AM
