My map sensor is throwing a code, I am going to boost , maybe not so bad???? plz help
Old Nov 28, 2003 | 07:18 AM
riddickone's Avatar
Default My map sensor is throwing a code, I am going to boost , maybe not so bad???? plz help
Heys guys I got a 95 Teg GSR and the map sensor is throwing a code, MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor, ok so I am going to turbo the car within the next couple of weeks and I am going to either do uberdata being that it is free, or actually go with a Hondata if I can get the money up,
My ?? is should I go ahead and get another stock map sensor or should I just go ahead and get a gm 3 bar, and wire it up . And will it affect the idling or driving of the car until I get it boosted, Cause I plan on running 12 psi daily, so what do you guys think?
Also this may be a stupid ?? but where does the 3bar map go , surely it does not fit the intake manifold right?? or do you just leave the stock map on the manifold and the run the line and wires to the 3 bar map. thanks
Modified by riddickone at 4:31 PM 11/28/2003
Old Nov 28, 2003 | 09:53 AM
baphomet's Avatar
Default Re: My map sensor is throwing a code, I am going to boost , maybe not so bad???? plz help (riddickon
AFAIK your car will run like crap with the 3 bar and no management - put the 3 bar in after you get some engine management.
Old Nov 28, 2003 | 10:21 AM
riddickone's Avatar
You mean Uberdata or Hondata??? I guess???
Old Nov 28, 2003 | 10:23 AM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riddickone &raquo;</TD></TR><TR><TD CLASS="quote">You mean Uberdata or Hondata??? I guess???</TD></TR></TABLE>
Either of those will do, make sure you get the 3bar uberdata if your using the 3bar map sensor.
Old Nov 28, 2003 | 10:26 AM
falcongsr's Avatar
What is this crap?
you have to fix your car before turboing it
Old Nov 28, 2003 | 10:32 AM
Flamenco-T's Avatar
first thing, GM 3 bar map sensor will prolly not run with stock ECU.
Second, to install the GM 3 bar, you need to cut the harness off of the stock map sensor, splice it to the GM map and run a vaccum line from the map sensor to any vacuum source.
Third, to solve your problem, does your car idles like crap now ? if so, try to see the rubber o-rings in between the map sensor and the TB, it may have been torns and etc..
stan
Old Nov 28, 2003 | 12:19 PM
riddickone's Avatar
It actually idles fine right now but when I always hit vtec at 4400 rpm , I get a CEL and two codes code 3(map) and code 22(vtec oil pressure switch), but there is plenty of oil in the motor and just had it changed 3 days ago. Any other suggestions thanks
Old Nov 28, 2003 | 12:26 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riddickone &raquo;</TD></TR><TR><TD CLASS="quote"> Any other suggestions thanks</TD></TR></TABLE>
I don't know - replace the broken pieces
teg_95
Apr 28, 2009 07:19 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
5thgen
Oct 17, 2005 07:11 AM
CiViC SiR
Jul 7, 2003 02:55 PM
fast[R]
Jul 18, 2002 03:00 PM
