what rings do i run
Old Feb 16, 2005 | 10:35 AM
dartcivic's Avatar
Default what rings do i run
i have a high HP, FI (30 psi) dart block being built for my civic,
thanks for any help in advance !!!
todd
Modified by dartcivic at 4:29 PM 2/16/2005
Old Feb 16, 2005 | 01:50 PM
NJIN BUILDR's Avatar
Default Re: what rings do i run (dartcivic)
I would go with the same as the pistons that you are using.No real reason other than convenience,they are all high quality,including the stock hondas.
Glenn
Old Feb 16, 2005 | 02:21 PM
NVturbo's Avatar
O.G. triple O.G.
I have Wiseco pistons in my setup and the Wiseco rings/seals that came with the pistons works great. Plus, if you were to just buy the rings/seals, they run roughly about $85 (Race Engineering out of Florida).
Old Feb 16, 2005 | 02:58 PM
blackmagicCRX's Avatar
Default Re: what rings do i run (NVturbo)
how do u determine the ring gaps based on your application?
Old Feb 16, 2005 | 03:00 PM
SPOOLINmatt's Avatar
Default Re: what rings do i run (blackmagicCRX)
usually the manufacturer can help you out on that. give them a call .
MurtazaDSM
Feb 14, 2015 07:54 AM
TwoKSiR
Jan 29, 2010 01:00 PM
crex23
Feb 2, 2006 05:41 PM
vtec.dc2
Sep 28, 2003 12:19 PM
