turbo s2k missfire
turbo s2k missfire
I did my research on s2ki and couple threads on ht everyone who does forced induction uses the Denso IK24 cold plugs....i ordered those suckers....i put em in...drove the car for about 5 minutes...engine check went on..the codes are p-0301, 0302 and 0303 which is cylinder 1, 2, 3 missfiring...( why not 4?) but anyways i decided to put my stock ones back in...as i was changing them...my new spark plugs were **** color black on the tips.........so i put the old ones back in drove around...the car was driving alot smoother and much faster.....10 minutes later...the engine check went on again as i was entering my lil st...it bogged once and then i parked the car....anyone got any idea as to wtf is going on?
Re: turbo s2k missfire (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">bad tuning? what are u using for fuel management?</TD></TR></TABLE>
Definitley sounds tune related. We need some more info..
Re: turbo s2k missfire (92jdmhatch)
my brand new spark plugs...the tips are blacker then black....and if it is tuning? wut the hell do u tune?....im thinkin of going with the aem ems....but im still savin up for that suckerr...but for now...im called autolink in temple city...they told me the vortech should be fine for now
I do not suggest FMU's, all they do is rise the fuel pressure per psi. its a mere bandaid fix.
the stock ecu is thinking you have the stock injectors, not the 440's, you're probably running terribly rich at every load point.
yes get the aem, and find a competent tuner (the hardest part).
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I haven't dealt with one, what exactly does it do.. can you set it in any way?</TD></TR></TABLE>
i believe so but i could be wrong...i didnt touch it...wut he gave me...i slapped on my car.....he is a good friend...i am not able to get in touch with him at the moment..i think he is out of town
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I will let other people chime in, but if you have the money and can do it sometime in the future, definitley get some kind of EMS, don't want to blow that nice S2K motor.</TD></TR></TABLE>
o fo sho...the ems is comign soon..i got some books to pay for for school....which doesnt leave me enough for that ems...but hopefully within a month or 2...i should be getting it....
I agree, the poor thing is running pig rich without any control. I suggest installing the stock injectors if you are keeping the FMU for now, and turn the boost way down.
Re: (Boondock Saint)
my friend has the same problem. he just went and borrow a Apexi VAFC to correct the fuel and i think he just got and tuned his car with the AEM. He said it's night and day. fund is always an issue. good luck. Oh. for his map, he used check valve from the fish tank.
Re: (hitvtecgetloud09)
injectors have nothing to do with it....(mr marouj's word from pacman) he says i am running very rich....it is because i am getting to much fuel...injectors r not my problem its my fuel pressure....my fmu is t'd off with a little **** to enable or disable more fuel from the line goin to my fuel pressure regulator....i dont know how much to open or close that sucker...best advice was get the ems...fuel gauge and fuel pressure regulator..
aznfoboi25
12-03-2006 08:15 PM
2000vsm
10-20-2003 09:20 PM
