vacf good?
Old Feb 14, 2005 | 02:05 PM
forcefedh22's Avatar
Default vacf good?
I have a h22 with a garrett t3/t4 turbo. I already have a vafc, so I dont really want to get rid of it. I know hondata or uberdata would be better but money is short. Would a vafc do the job? anyone had any luck with forced induction?
Old Feb 14, 2005 | 02:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: vacf good? (accordh22turbo)
search for vafc hack and dsm 450's
i have never used it and am a proponent of hondata.
Old Feb 14, 2005 | 02:48 PM
93turbo16's Avatar
it will work, but why wouldn't you go uberdata when it costs just as much.
Old Feb 14, 2005 | 02:50 PM
beepy's Avatar
Sell the VAFC on Ebay and use the proceeds to chip for Uberdata.
Old Feb 14, 2005 | 02:53 PM
Default Re: vacf good? (beepy)
I thought about that.
Old Feb 14, 2005 | 02:55 PM
how "flexible" as far as tuning is uberdata? how hard is it to tune. I have a wide band. Will that be ok?
Old Feb 14, 2005 | 02:56 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Sell the VAFC on Ebay and use the proceeds to chip for Uberdata.</TD></TR></TABLE>
That's your best bet^^^^^^^^^^^^^^^
With no way to retard timing under boost you will be sure to spend more money in the long run. Just a heads up. If you can get your hands on a BTM that would be the only way I would say to "safely" use the hack.
Phil
Old Feb 14, 2005 | 02:58 PM
beepy's Avatar
I would try to solicit for Uberdata maps from people on this forum. Seems a lot of people use it, bound to be someone who has an application similar to yours.
Many people recommend dyno tuning, but I say with a wideband and a EGT, you can tune anything.
Old Feb 14, 2005 | 03:01 PM
BlueShadow's Avatar
Yah, I would not even wanna use a VAFC, especially with the free software out there.
Check out these two threads:
https://honda-tech.com/zerothread?id=1147922
https://honda-tech.com/zerothread?id=1139873
Old Feb 14, 2005 | 03:41 PM
hondaguyef's Avatar
Many people recommend dyno tuning, but I say with a wideband and a EGT, you can tune anything.</TD></TR></TABLE>
Are you my twin?.
Phil
Old Feb 15, 2005 | 04:56 PM
Default Re: vacf good? (hondaguyef)
so a vafc is ok as long as it has been dyno tuned??
Old Feb 15, 2005 | 05:34 PM
beepy's Avatar
No. There are two ways to use an AFC and two reasons why you cannot use them for a turbo safely:
1) The AFC can remove enough MAP signal to allow you to have a turbo without modifying the MAP sensor. The flaw: The ECU reads less load on the engine and advances timing. This is dangerous.
2) The AFC can allow you to add more fuel or use larger injectors by adding to or removing some of the MAP signal. Besides the above timing issues, the flaw is that the AFC is RPM-dependant, while boost from a turbo is NOT RPM-dependant.
This is intermediate algebra. There is no single "formula" that will allow you to relate two functions which are dependant on different variables. Therefore, you will run into a situation where boost comes in when you don't expect it (like passing on the highway), and the engine will go dangerously lean. This is also dangerous.
Now, an AFC along with a BTM can, IMO, be used to sucessfully tune a supercharger application, since a blower's boost IS basically RPM dependant. But that's a different thread altogether.
2000SICVC
Engine Management and Tuning
Aug 25, 2010 05:29 AM
00BoostedGSR
Aug 1, 2006 10:46 PM
93h22a1vtec
Dec 20, 2005 11:40 AM
sh-ef
Jun 28, 2004 07:15 AM
hityouwithabang
Aug 24, 2003 01:59 PM
