tips on drilling oil pan for oil return fitting?
what tips can you guys give me on drilling the oil pan? i read that its made of steel, and steel is pretty hard to drill into. thanks.
you have your tubro returning the oil to the back of the block? how does that work for flow? how long have have you been running this setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinwipf »</TD></TR><TR><TD CLASS="quote"> well it has an adapter that comes from a fitting that goes infront of your oil filter. this way you get filtered oil as well as a clean install. </TD></TR></TABLE>
FYI, after the oil goes through the oil filter, it goes to your pressure sensor (where most people tap)
On the oil pan, I always suggest putting the whole turbo kit on and leaving the pan on the motor until ever other part is on. Leave the drain hose hanging off the turbo, and just take a look at the pan and the position of the turbo. This visual should give you a good idea of how you can make the best sloped drain. Mark the pan, take it off, and drill.
D16y8_619
Sep 8, 2006 09:05 PM
Sprockets
Aug 8, 2005 01:53 PM
