smoke coming from breather
Old 02-12-2005, 11:49 PM
tuner_3's Avatar
Default smoke coming from breather
i dunno whats going on...i just turbocharged the car, drove to work and now smoke is coming out of the breather...rpms drop and vacuum is higher than usual...no sign of detination because the car drives normal and there is no sign of water in the oil...the car is still smoking grey not blue...no check lights just smoke from the breather and low rpms...the car even died on me...the smoke smells like gas...please help!
Old 02-13-2005, 04:56 AM
DRAGLS's Avatar
Default Re: smoke coming from breather (tuner_3)
stock motor right? You may have leaned out slightly now you have blowby-more than normal.
Old 02-13-2005, 06:47 AM
5thgencivic's Avatar
Default Re: smoke coming from breather (DRAGLS)
Most likely rings or cracked ringlands.
Old 02-13-2005, 10:57 AM
tuner_3's Avatar
Default Re: smoke coming from breather (5thgencivic)
can it be fixed...
Old 02-13-2005, 11:30 AM
Rod.'s Avatar
you can get new rings
Old 02-13-2005, 12:02 PM
Stewie's Avatar
Default Re: smoke coming from breather (redturbocivic)
you have to do a compression/ leakdown test to see what's the problem
Old 02-13-2005, 01:16 PM
adseguy's Avatar
Default Re: smoke coming from breather (Stewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you can get new rings</TD></TR></TABLE>
stock honda rings are pretty dman solid.....it's usually the ringlands that will crack.
If you are always getting smoke now you prolly blew up your motor (cracked ringland) The only way to get it fixed is to get a rebuild
Do a compression test and that will give you some answers
Old 02-13-2005, 01:49 PM
tuner_3's Avatar
Default Re: smoke coming from breather (adseguy)
thanks...im sure its the ringlands.
Old 02-13-2005, 02:19 PM
riceburnah's Avatar
yup ringlands samething happened to me just much worse.
Old 02-13-2005, 07:06 PM
PrettyLude's Avatar
Default Re: smoke coming from breather (riceburnah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnah &raquo;</TD></TR><TR><TD CLASS="quote">yup ringlands samething happened to me just much worse. </TD></TR></TABLE>
me 2, crack 3 pistons
Old 02-14-2005, 01:18 PM
tuner_3's Avatar
Default Re: smoke coming from breather (PrettyLude)
yeah... sucks i wanted to get my car on the dyno and get it tuned with urbendata..but this happened...looking for a motor though...
Old 02-14-2005, 03:31 PM
BCICAN
Dunc's Avatar
Yep, we had the same exact problem with a GSR that came in for some tuning. I got in the car, turned it on, and smoke just started pouring from the breather. We did a compression test and number 3 cyclinder was like 105 and the rest were 195 I think...I can't remember exactly. But yea do a compression and leak down.
Old 02-20-2005, 10:35 PM
tuner_3's Avatar
Default Re: smoke coming from breather (Dunc)
yep...i'll make sure i'll do that...does anybody know the price for a b18b longblock...i need a motor for now...thanks
Old 02-20-2005, 10:42 PM
mrDFWmechanic's Avatar
all depends on where you look i got mine for 400 from a friend.
Old 02-21-2005, 08:46 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner_3 &raquo;</TD></TR><TR><TD CLASS="quote">yeah... sucks i wanted to get my car on the dyno and get it tuned with urbendata..but this happened...looking for a motor though...</TD></TR></TABLE>I refer you back to my break-in thread that says TUNE FIRST before you jump on it
https://honda-tech.com/zerothread?id=878397
Metal Head
02-19-2009 08:37 PM
cleanej2
15
10-16-2008 12:38 AM
jadugartir
08-01-2004 07:05 AM
1SickHb
17
03-08-2004 01:43 AM
Night Kid
10-18-2001 11:22 AM
Quick Reply: smoke coming from breather
