BOOST ON A 85.5MM bored sleeved block?
heres the story, engines first build was 84.5 bored out darton mid....F*cked that up so now i had to bore it out to 85.5mm with 10:1comp arias pistons how much should i boost? should i keep it low? or just run high boost? .......
Re: BOOST ON A 85.5MM bored sleeved block? (PIFFSTAR)
why did you got 1.0mm over you really must have screwed the block up .5mm over at 85mm would have been a better choice. the darton mid at 85.5 is gonna be thin at best. I would reccommend low low boost any detonation or anythign that cause severe pressure on the side wall will crack that bitch in two
Re: BOOST ON A 85.5MM bored sleeved block? (b18bturbo)
man that sucks ....... yeah i figured that i'm making plans for a new block keeping it safe at 81mm
