just a lil nitrous question
Old Feb 13, 2005 | 12:42 PM
BlackOnBlackTeggie's Avatar
Default just a lil nitrous question
i have a 50 wet shot in my gsr and i melted a plug the other night so i pulled timing back 2 degrees and got new plugs, so i got NGK zfr5f-11 . they are 2 steps colder then stock but they look like they are a bit longer after the treads, like the part that is in the combustion camber. any one use these plugs?
Old Feb 13, 2005 | 12:56 PM
W O T's Avatar
Default Re: just a lil nitrous question (BlackOnBlackTeg)
isnt this a plug question?
Old Feb 13, 2005 | 01:07 PM
Default Re: just a lil nitrous question (W O T)
nitrous-plugs sorry, do you know the answer, if not dont post.
Old Feb 13, 2005 | 01:13 PM
beepy's Avatar
Put one in the engine. Spin it over by hand. If it contacts then don't use them.
I don't think anyone has a interference cross-reference for every single plug out there.
Old Feb 13, 2005 | 04:09 PM
Goinfasterthanu's Avatar
If your running a wet setup you should NOT have to retard the timming at all...Look at fuel pressure or might be the nozzle facing a little off....
Old Feb 13, 2005 | 04:56 PM
Default Re: (Goinfasterthanu)
i have an all motor ecu, that advances timing. it could have been the nozzle. i moved the location, ill have to try it out and see how it feels.
Old Feb 16, 2005 | 12:17 PM
IROSOLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackOnBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">i have a 50 wet shot in my gsr and i melted a plug the other night so i pulled timing back 2 degrees and got new plugs, so i got NGK zfr5f-11 . they are 2 steps colder then stock but they look like they are a bit longer after the treads, like the part that is in the combustion camber. any one use these plugs?</TD></TR></TABLE>
Use NGK POWER-9 AKA V-9. Im running a 100shot and my Dyno tuner guy recommends those plugs on nitrous. They run alot cooler.
Old Feb 16, 2005 | 02:02 PM
mrbsponge's Avatar
Default Re: just a lil nitrous question (IROSOLO)
dude! WTF, you dont need to retard timing on a wet kit??????? WTF kinda answer is that????
that is why peoples **** gets blown up.
the number in the ngk plug such as bkr7e11, the first number represents the heat range, such as a range of 7 this is a pretty cool plug, you have the 5 series that is a hotter plug more along the lines of an allmotor plug.
the higher the number the colder the plug. if you find some 7s 8s or 9s, you will notice the electrode tip is getting lower and lower as the number goes up, thus trying to reduce the heat range and chance of it melting.
if you have an allmotor ecu, such as a spoon, js-racing,mugen, all of thos give major advances in timing, so i would pull 2 degrees to be safe
Pullig
Apr 17, 2006 08:23 AM
Pullig
Apr 5, 2006 10:54 AM
RedRocketCRX
Nov 16, 2004 08:04 PM
hondaeg5
Dec 22, 2002 09:17 AM
