.::need info on 86mm gsr::.
has anyone run the big a bore on a street car? just wondering I saw in the all motor forum that people had problems with head gaskets sealing? any info would help. btw mine is a darton sleeved 86mm gsr block.
Who is Mr Robot?
Re: .::need info on 86mm gsr::. (kevino002)
i wouldnt for fi on anything over an 84.5mm bore. to liitle material left on the slleves, yes even if it s sleeved
there seems to be alot of materail left on the sleeve, darton garentees the sleeves will hold 30+ psi.
We tried 85.5 on a friends B16. Didn't hold HG's worth crap, and it started to see blowby not long after we got it running, I think the cylinders became out of round. I would sell the block and start fresh, or have it resleeved.
Re: .::need info on 86mm gsr::. (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite »</TD></TR><TR><TD CLASS="quote"> I would sell the block and start fresh, or have it resleeved.</TD></TR></TABLE>
I agree the biggest we run turbo motors are 84.5mm.
Chris
Chris
Re: .::need info on 86mm gsr::. (BlueHatch00)
Thats not what I wanted to hear. lol
I think that I will try and see what happens, it I have problems then I will just start over.
When you do it, have the machine shop use a torque plate to do the hone. It will keep the cylidners more true. - A good guy on this board gave me that very helpful tip. There are a few guys in the all motor forum running 87mm bore on a B Series.. Just make very sure both surfaces are flat as possible.
B19 coupe also had luck with indian head gasket sealer. I am anxious to here out it goes.
My 86mm motor shoul dbe done tommorrow night.
Re: .::need info on 86mm gsr::. (asubennett)
The block is at the machine shop as we speak should be done friday. I will let you all know how it goes.
my block is bored out at 85.5mm with dart MID sleeves i'm currently in the break in period, rev limiter set at 5000rpm 5pds of boost i put about 3000k on the motor since it was built.... just waiting on some $$$ to go tune but, going to play it safe keeping the boost at 10pds when i tune..but i'm making plans to build another block tho. i just have a slight feeling that block is going to go PINNNGGGGGG!!!!!!!!!!!!
Re: .::need info on 86mm gsr::. (PIFFSTAR)
well I guess we will see, eveyone at the shop says that it will be fine that I am just worring about it to much.
I agree. I think a lot of people shy away from 86mm becasue they are told it is impossible.
I too was scared in the beginning because of what I heard. The only con is that you at your limit so if something does break it doesn't leave much room for correcting it. I would not be afraid to boost like on the 86 just as you would on a 85 or an 84. If it blows the gasket then dial back the boost.
Best of luck to you. Rememebr that flat surfaces are your freind. take some material off the deck of the block if you have to.
well I finally got the car on the street. I took it to the dyno and found out that I need to replace the coil and one of the spark plug wires was bad so I just got a MSD 6Al and some MSD plugs. I went back to the dyno about a week later and was only able make one pass, the injector on #4 cyle. was not working, so I make just under 300whp at 6-8psi with only 3 cylenders. I am going to replace the injectors this week and get it back on the dyno. I have put about 500 miles on it boosting 6-8psi before the injector went. will update soon.
Have been running the motor for about 6 months on 8-9psi and have had no problems with the HG, going to the dyno soon to tune for higher psi and more power, will keep you updated.
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevino002 »</TD></TR><TR><TD CLASS="quote"> so I make just under 300whp at 6-8psi with only 3 cylenders.</TD></TR></TABLE>
who in CO is tuning it?
you should contact servion (he is on here) , he is the man iin CO for tuning hondas
tell him Kelly sent ya
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevino002 »</TD></TR><TR><TD CLASS="quote">He is tunning my car... Has been since I switched from Hondata to Neptune.</TD></TR></TABLE>
joepiscapo_83
04-13-2005 01:41 PM
