BBKA goes to the track and runs 12's... SOHC Power!
Went to the first test and tune this season and finally got to try my new slicks. I am having trouble with my internet at the moment, so I can't make a very big post, but here is a little info.
95 Civic Coupe EX w/full interior
D16Z6 w/stock internals
Custom turbo kit at 12psi, t3 60 trim .60/.48
23x8x13 MH slicks
13x8 Weld Racelite drag wheels
Y8 tranny w/Quaife LSD
H&R sport springs
Tokico illuminas
Best time: 12.685 @ 107.46 mph, 1.78 60 foot (boost 12psi, tires 10psi)
Modified by beerbongskickass at 5:08 AM 2/16/2005
23x8x13 MH slicks
H&R sport springs
Tokico illuminas
Who is Mr Robot?
Re: BBKA goes to the track and runs 12's... SOHC Power! (beerbongskickass)
nice numbers. i bet you did all of this with a corona in your left hand too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Went to the first test and tune this season and finally got to try my new slicks. I am having trouble with my internet at the moment, so I can't make a very big post, but here is a little info. I will update it later with my timeslip.
23x8x13 MH slicks
H&R sport springs
Tokico illuminas
Best time: 12.685 @ 107.46 mph, 1.78 60 foot (boost 12psi, tires 10psi)</TD></TR></TABLE>
i heard about you. my friend was at sir as well and told me that you were the fastest import that day. nice numbers and props.
I probably will be there next week if they are having test and tune on sunday again.
23x8x13 MH slicks
H&R sport springs
Tokico illuminas
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">I am having trouble with my internet at the moment, so I can't make a very big post, but here is a little info.
Re: BBKA goes to the track and runs 12's... SOHC Power! (redturbocivic)
Nothing about my setup is different... I have only been to the track 3 times ever, so I just improved on my driving skills. My first time at the track I made 4 runs on used 22 inch slicks, my second time I was on drag radials. This time I just turned the boost up to 12psi, launched off the rev limiter, and never let off the gas until I was across the finish line.
I made 6 runs yesterday...
Run 1: 13.3 @ 102 mph, 1.93 60 foot (boost 10psi, tires 12psi)
Run 2: 14.0 @ 101 mph, 2.30 60 foot (boost 10psi, tires 12psi) redlight and shitty launch.
Run 3: 13.1 @ 104 mph, 1.97 60 foot (boost 11psi, tires 10psi)
Run 4: 12.845 @ 106.90 mph, 1.83 60 foot (boost 12psi, tires 10psi)
Run 5: 12.689 @ 107.21 mph, 1.80 60 foot (boost 12psi, tires 10psi)
Run 6: 12.685 @ 107.46 mph, 1.78 60 foot (boost 12psi, tires 10psi)[/b]
I still thnk there is a little left in my car.
Pat
Pat
Re: BBKA goes to the track and runs 12's... SOHC Power! (Civicman86)
Damn!
Very nice
12's in a coupe with a stock d16z6.... has this been done before? Or are you the first? Most people with built engines don't run those times...
SOHC Powa!
Very nice
SOHC Powa!
Re: BBKA goes to the track and runs 12's... SOHC Power! (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">What did you launch at?</TD></TR></TABLE>
The rev limiter (about 7300 rpms)
I probably could have ran even better times if I raised the rev limit to like 8,000 rpms and lowered my tire presure a little more (7-8psi maybe). First gear was flying by pretty fast.
I probably could have ran even better times if I raised the rev limit to like 8,000 rpms and lowered my tire presure a little more (7-8psi maybe). First gear was flying by pretty fast.</TD></TR></TABLE>
I was going to say you should have lowered the tire pressure. 8 would have been a good start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">The rev limiter (about 7300 rpms)
what about your axles
Stock axles and launching at the rev limiter? I have some 24.5x8x13 Mickey Thompson ET Drag Slicks and I want to go to the track this season. I'm on AutoZone axles and am curious what I should launch at. I was also thinking of starting with 10psi tire pressure. Great numbers!
Edit nvm some one beat me to it, god damn this thread moves fast.
Re: BBKA goes to the track and runs 12's... SOHC Power! (Vtaaak y0)
This was on stock d-series axles. I was pre-loading the clutch, so basically it was right at the point of engaging when I dropped the clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">This was on stock d-series axles. I was pre-loading the clutch, so basically it was right at the point of engaging when I dropped the clutch.</TD></TR></TABLE>
What do you mean? Using a steady foot to hold the clutch pedal right before the point of engagement?
