how to install oil feed line etc etc
Hey its a b18 T3/t4 turbo going in my civic,i need to know how to install the oil feed lines for the turbo,the oil i should use, and most inportnatly the torque specs for a b18 and turbo parts.
Re: how to install oil feed line etc etc (Tofu94)
You tap into the oil supply at the back of the block..Run a t-fitting of some sort..Run the feed line to the turbo...Then run the return line from the turbo back to the oil pan..(Make sure this line isnt kinked)..Drill a hole into the oil pan and weld(or jbweld) in a fitting to accept the oil return line...
I like that cheap oil..10w-40 in some cheap ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofu94 »</TD></TR><TR><TD CLASS="quote">and the turbo acts as a pump for the oil by itself correct?
the oil pressure from the engine, gets the oil to the turbo.
platinum.
platinum.
Re: how to install oil feed line etc etc (platinum00)
will this cause a drop in oil pressure and effect vtec? also should i add more oil to the engine since some will be in the turbo and lines?
Does anyone have a link of where i could get the oil feed lines and return lines for my application,B18 turbo?
Fittings:
https://honda-tech.com/zerothread?id=1011921
It won't cause a drop in oil pressure, because there is very little flow to the turbo, if done correctly.
killamike0001
09-06-2007 12:22 PM
