Cam rockers....
Old Feb 14, 2005 | 04:34 PM
Bulldogg83's Avatar
Default Cam rockers....
Have a real quick question......are all VTEC Cam Rockers interchangeable? For instance I have a b16 head that needs to have the cam rockers replaced due to damage caused by a spun bearing. Would I be able to use GSR/ITR cam rockers if I can not find any b16? Thanks for the help!
Old Feb 14, 2005 | 05:09 PM
adictionbass's Avatar
Default Re: Cam rockers.... (Bulldogg83)
i would ASSume so, ill try to look around and see if i can find anything.
Old Feb 14, 2005 | 05:20 PM
Default Re: Cam rockers.... (adictionbass)
ok well the 95 del sol vtec coupe and 99 civic si's rocker assemblies are the same. (but they are both b16s) The honda part number is: 14620-P30-000
If no one replies here, i would call acura and ask for the p/n for the gsr and/or type r assemblies. If they are the same number, they are obviously interchangable. I dont know any acura parts cataloges online that have the actual p/n so i couldnt check. hope this helps some.
Old Feb 14, 2005 | 07:49 PM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">ok well the 95 del sol vtec coupe and 99 civic si's rocker assemblies are the same. (but they are both b16s) The honda part number is: 14620-P30-000
If no one replies here, i would call acura and ask for the p/n for the gsr and/or type r assemblies. If they are the same number, they are obviously interchangable. I dont know any acura parts cataloges online that have the actual p/n so i couldnt check. hope this helps some.</TD></TR></TABLE>
Thanks for the help man!
Old Feb 14, 2005 | 08:15 PM
Cjsls's Avatar
okay im getting the same part numbers for the gsr/itr (pn14620-P30-000) from this site
http://www.acuraparts247.com/s...e.jsp
Old Feb 14, 2005 | 08:20 PM
Default Re: Cam rockers.... (Cjsls.com)
ill be putting that under favorites. Been looking for an acura cataloge for a while.
They are the same then.
96ej8MR
Sep 25, 2008 08:10 PM
thielkedelsol
Apr 19, 2006 06:47 PM
thielkedelsol
11
Apr 13, 2006 06:13 PM
IHeartMyAcura
Nov 14, 2005 06:43 PM
LB CRX
Apr 5, 2002 09:20 PM
