Supercharged Exhaust Recomendation
Old Feb 16, 2005 | 09:28 AM
eg6hatch's Avatar
Default Supercharged Exhaust Recomendation
I have a 1997 Supercharged Integra GSR, Jackson Racing, and i have a apexi world sport 2 on it now, and i have a feeling i could be alot more open with soemthing else, what do you guys think, apexi n1, or what? thanks
Also the world sport is 2 1/4" i think, what size piping should i get, 2 1/2" or 3", it is a supercharged gsr, dc 4-2-1 header, injen intake, and a couple more bolt ons.
Old Feb 16, 2005 | 10:19 AM
beepy's Avatar
Default Re: Supercharged Exhaust Recomendation (eg6hatch)
Exhaust size is much less important on a SC app than a turbo. Just follow a simple formula.
Take the amount of boost you plan to make, convert that to absolute atmospheres. Now multiply that value by the displacement of your engine. That will give you a very rough estimate of the exhaust airflow requirements.
For example, say you have a 1.8 liter with 14.7 PSI of boost. That is 2 atmospheres absolute, so your engine will act similarly to a 3.6 liter engine. Now what size of exhaust does a 3.6l need? I would say about 2.25" is plenty, and any more you would lose lowend torque.
Old Feb 16, 2005 | 02:47 PM
eg6hatch's Avatar
Default Re: Supercharged Exhaust Recomendation (beepy)
ok, so if i run 8 psi, on a 1.8, what size would i need, so if i buy the 2.36" n1, would i lose low end
Old Feb 16, 2005 | 03:45 PM
Tad's Avatar
Tad
ok whats absolute atmospheres...
Old Feb 16, 2005 | 04:22 PM
beepy's Avatar
Default Re: Supercharged Exhaust Recomendation (Tad)
There are gauge atmospheres, as in, "I made 1 bar of boost". Then there are absolute atmospheres, as in, "I have a 3-bar MAP sensor".
In a perfect world, if you make a bar of boost, you have 2 bar of pressure in the engine, which will be twice as many moles of air if at the same temperature. (This is a conservative estimate, in reality there will be less than 2x the moles of air)
In a perfect world again, if you have twice as many moles of air, you would need twice as much fuel, and you would have twice as much exhaust. Thus the conservative estimate is to treat the engine as having twice the displacement.
Old Feb 16, 2005 | 05:24 PM
Tad's Avatar
Tad
so what you're saying is that if your running 1bar of boost then you can
treat it as if your engine has twice the displacement?
Old Feb 16, 2005 | 05:31 PM
Muckman's Avatar
Moderator in Chief
Its easy, just get a 3".
Old Feb 16, 2005 | 05:36 PM
beepy's Avatar
Default Re: Supercharged Exhaust Recomendation (Muckman)
Yes, but only for a supercharger application, and again it's a rough estimate. 3" on a 1.8 liter with 1bar of boost is way overkill. My 5.7 liter, 385 ft-lb Camaro engine only had a single 3" exhaust.
Old Feb 16, 2005 | 08:44 PM
eg6hatch's Avatar
so would a apexi n1 at 2.36" be ok?
Old Feb 16, 2005 | 08:50 PM
Tad's Avatar
Tad
perfect imo
i'm running a kinda stepped setup,
stock header.. 2.25 ITR bpipe, then 2.5" axleback..
I think its good? hehe..
Old Feb 16, 2005 | 08:58 PM
eg6hatch's Avatar
so will 2.36" on my car be ok, apexi n1 that is?
Old Feb 17, 2005 | 06:26 AM
Muckman's Avatar
Moderator in Chief
Im pretty sure all Apex piping is 2.36" (60mm). Sure it'll be ok. Not the best, but ok.
Old Feb 17, 2005 | 06:40 AM
eg6hatch's Avatar
ok, then what would be the best exhaust for my car?
Old Feb 17, 2005 | 03:00 PM
eg6hatch's Avatar
SO should i buy the n1, or another exhaust
Old Feb 17, 2005 | 03:13 PM
Muckman's Avatar
Moderator in Chief
3" > 2.5" > Apexi WS/N1 2.36"
Old Feb 17, 2005 | 03:57 PM
beepy's Avatar
Don't get stuck with "the bigger the better" here. If anything, exhaust scavenging is MORE important with a supercharger than N/A.
Old Feb 17, 2005 | 05:28 PM
Muckman's Avatar
Moderator in Chief
Right. no bigger than 3" then
Old Feb 17, 2005 | 05:48 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Don't get stuck with "the bigger the better" here. If anything, exhaust scavenging is MORE important with a supercharger than N/A.</TD></TR></TABLE>
what do you mean by exhaust scavenging?
Old Feb 18, 2005 | 07:18 AM
eg6hatch's Avatar
I just want to know whetehr i should buy the apexi n1 in 2.36", or get something else
!!miguel!!
Nov 23, 2009 09:06 PM
Got Milk
Aug 2, 2004 12:12 PM
Badger401
Jul 30, 2004 01:28 PM
mantic6t9
Sep 9, 2002 08:34 AM
