power@half throttle, none @ full?
Old 02-12-2005, 08:38 PM
forcefedh22's Avatar
Default power@half throttle, none @ full?
I have a h22 with a garrett t3/t4 turbo, fmu ,stock injectors, 255lph pump, vafc, and a missing link. When I mash the throttle down it has good power untill the wastegate opens, Then it flutters and looses power. If I just give it 40% throttle and let it build 5psi instead of six (when the wastegate opens) it has great power. I know this might sound like a stupid question but I'm stumped.
Old 02-12-2005, 08:44 PM
PureTeg420's Avatar
Default Re: power@half throttle, none @ full? (accordh22turbo)
are you using anything to retard the timing for every lb of boost? It's probably unrelated to your problem, but if your not, your motor will be dead soon. Also, you're using an FMU and stock injectors, you should really be using an inline pump because I'm sure your fuel pressure is high. In fact it might be high enough that your walbro pump cannot keep up, and once you reach full boost your motor is running extra lean
Old 02-12-2005, 08:48 PM
Default Re: power@half throttle, none @ full? (PureTeg420)
nope, I have an msd 6al I should probably get a boost timing master.
Old 02-12-2005, 08:49 PM
oh, ok that might be why its flutters and looses power. thanks alot .
Old 02-12-2005, 09:08 PM
PureTeg420's Avatar
no problem. It definatly sounds fuel related to me. You should look into borrowing a buddy's wideband o2, or hopping onto a dyno w/ a wb02 before you start throwing money at the problem. Nothing more frustrating then buying new parts and still having the same problem
lil_williams
06-11-2007 06:14 AM
imskatencrzy
03-22-2007 07:10 PM
99lspwr
11-11-2005 10:40 PM
AutoTrenz702
04-11-2005 02:43 AM
BoOsTiN Dc2
11-21-2003 08:12 PM
Quick Reply: power@half throttle, none @ full?
