throwing solid cel....cose 0 ecu need help
Old May 18, 2005 | 07:31 PM
civic_jdm's Avatar
Default throwing solid cel....cose 0 ecu need help
I was at track and went to change chip and went to start car and wouldnt start for ****. Changed chips back to good known working chip and nothing again.. Throws CEL and it stays on when you jump conversion harness cel wire. Code 0(ecu) Wont start, gets fuel and spark but seems to have a problem. Back up fuse and ecu fuse is good and so is main relay....any idea?????? Tried another known ecu also...same results
Old May 18, 2005 | 08:08 PM
civic_jdm's Avatar
could a wire touching another wire like on o2 sensor cuz it to throw a code 0 solid cel and not start. i didnt think so but also dont know everuything
Old May 18, 2005 | 09:30 PM
iBrandon's Avatar
Default Re: (civic_jdm)
same thing happen to my p72 ecu...mite of fried the ecu...at least mine did
Old Jun 5, 2005 | 10:26 PM
mtber's Avatar
Default Re: (Shy Gsr)
A solid cel usually means you have a ecu malfunction such as a bad ecu.
Try another ecu.
Old Jun 5, 2005 | 10:31 PM
JDMlyfestyle's Avatar
did you happen to shock the ECU when you were changing chips? ive done it before and fucked up a ECU. so now i have a ground strap attached to my arm going to the door hing when im playin with ECU's
Old Jun 6, 2005 | 07:19 AM
xenocron's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">A solid cel usually means you have a ecu malfunction such as a bad ecu.
Try another ecu. </TD></TR></TABLE>
he did...said that in the 1st post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm &raquo;</TD></TR><TR><TD CLASS="quote"> Tried another known ecu also...same results
I would guess that when you were playing with the ECU, one of your harness plugs might have come loose.
I would doubt that you 'shocked' the ECU and ruined it though. I have played with HUNDREDS of OBD0/OBD1 ECUs and never once 'shocked' one to death.
Always ends up being a bad chip, a bad burn or wiring issues...ECUs are pretty solid pieces that rarely fail.
Old Jun 6, 2005 | 08:47 AM
legendboy's Avatar
Default Re: (xenocron)
sounds like you have a short somewhere in your harness. check to see if you have blown any of your ecu fuses
Old Jun 6, 2005 | 10:18 AM
xenocron's Avatar
Default Re: (legendboy)
Also, try the ECU in another car to eliminate the ECU being bad as well.
BIGef
Jul 31, 2013 03:52 AM
rizzuto
14
May 17, 2013 07:59 PM
mouab18c1
Engine Management and Tuning
35
Aug 31, 2010 05:31 AM
drumminforev
19
Oct 6, 2006 12:12 AM
