How much OIL?
Old May 18, 2005 | 05:22 PM
bennyhonda7's Avatar
Default How much OIL?
How much oil are you guys using with the turbo setups.?
Old May 18, 2005 | 05:25 PM
vtec.dc2's Avatar
Default Re: How much OIL? (bennyhonda7)
i normally run 1/2 a quart to almost a quart higher to compensate for turbo/oil lines.
Old May 18, 2005 | 05:28 PM
Default Re: How much OIL? (vtec.dc2)
thanks that is what i was thinking...is it necessary to use an oil catch can and if so how can i make one or where do i get one?
Old May 18, 2005 | 05:42 PM
vtec.dc2's Avatar
i use one.. my setup is b series..
i run pcv valve --> closed catch can (jaz catch can can be purchased from jegs, comes with drain valve) --> check valve --> intake manifold
for breather ports i run valve cover fitting open and i have additional fitting on top of engine oil cap added recently.
heres a good thread regarding catch cans https://honda-tech.com/zerothread?id=1199935&page=1
i'm adding aditional port to allow pcv valve to vent during boost. last picture i posted in that thread explains what i'm trying to do.. i'm almost done doing that setup
thread creator really knows what he's talking about, its very important to have a good ventilation setup.
datoad
Oct 5, 2017 08:31 AM
Set O' Nines
Oct 30, 2012 07:49 PM
Hybrid96EK
Jan 3, 2011 07:45 AM
soon2bdropped
Dec 16, 2010 07:40 PM
SkoundrelUSA
Oct 15, 2006 02:29 PM
