integra turbo question
Old May 17, 2005 | 11:44 AM
TEG777's Avatar
Default integra turbo question
hi iam going to be running a t3/t04e turbo on my integra, can i use a fmu for fuel maningment, with stock injectors, and how much psi can i run on that
Old May 17, 2005 | 11:51 AM
rmcdaniels's Avatar
Default Re: integra turbo question (boostinteg777)
Maybe 5-6 safely.
Old May 17, 2005 | 11:57 AM
TEG777's Avatar
Default Re: integra turbo question (rmcdaniels)
will i need a new fuel pump or will stock work
Old May 17, 2005 | 11:59 AM
s2kdre's Avatar
just use an intank pump and fmu only works with stock injectors anyways, and its safe up to 10psi, but i've seen 14psi, but it puts alot of strain on the fuel system.
Old May 17, 2005 | 12:10 PM
TEG777's Avatar
Default Re: integra turbo question (jdmhonda)
a stock intake pump or a walbro
Old May 17, 2005 | 12:16 PM
demotrek's Avatar
I ran 14psi for about a week with a fmu, turned it down to 8 and got a fuel pump and used it the whole time...ran fine
Old May 17, 2005 | 12:17 PM
rmcdaniels's Avatar
Aftermarket fuel pumps generally flow more fuel, but don't necessarily generate any higher pressure, and sometimes they won't make as much pressure as a stock fuel pump. When using an FMU, it's all about pressure, as the FMU will typically raise the pressure by 8-12 PSI per PSI of boost. So starting with around 40 PSI base fuel pressure, if you make 10 PSI of boost, then your pump will have to make as much as 160 PSI of fuel pressure, which many fuel pumps will not do. My fuel pump gave up before I got to 10 PSI, and I broke all my pistons as a result. I've heard of people running 8 PSI successfully, but that's pushing it. If you want to run more than 5-6 PSI, then get some real fuel management.
Old May 17, 2005 | 12:19 PM
TEG777's Avatar
Default Re: (rmcdaniels)
so can i use a stock pump or an walbro 255
Old May 17, 2005 | 12:22 PM
rmcdaniels's Avatar
I don't think it matters.
AZNracerx1989
Sep 23, 2005 11:28 AM
vietjdmboi
Jan 24, 2004 11:48 PM
importimage
Jul 11, 2003 03:45 PM
ludelvr
Apr 14, 2003 11:58 AM
red civic standard
Oct 10, 2002 07:47 AM
