oil feed line size?e
Old May 16, 2005 | 12:44 PM
project civic's Avatar
Default oil feed line size?e
I already searched and found many results but i have a gm t3/to4(IHI) turbo i believe and when i bought it, it came with a stock oil feed fitting already (-8an) and i know everybody recommends a -3 or -4 an feed line but the stock fitting is telling me to use -8an which is just huge. I have already ran this turbo with much smaller(-3an) feed line but the turbo seems to respond different every time i boost and it would build boost in different rpms every time and depending on how i drive it. The turbo has no shaft play and doesnt leak also spins freely.
Old May 16, 2005 | 01:04 PM
TURBO DC2's Avatar
so whats the question? I think most use -3 oil feed lines and also -4 with a restrictor
You could possibly try using a restrictor fitting with your feed line, but I would just buy a smaller line. You don't want to blow your seals
BigZeke5
Oct 16, 2008 06:20 AM
JohnData
Nov 18, 2007 05:39 PM
DEVIN22CBR
Feb 10, 2004 11:15 AM
