couple questions plus 500 hp monster pics
i did a compression check today the results were 155, 90, 155, 160. i poured alittle oil in the low one and the number went up to 175, so i am guessing the rings are shot. the question i have is, this is a built motor, arias pistons, scat rods, etc. all assembled by a trained engine builder, the thing was built last september and has been running a rock solid 7 psi, it is however untuned but i spent many hours street tunning it with a wideband, datalogging, and uberdata. boost is always 12 to 12.5, why would my rings be shot? should i contact the engine builder? how much time is need to replace the rings? can it be done with the motor in car?
now for the beast, i get some serious sh*t for driving a 4 banger (dads car)
71 nova
looks mean coming down the street
functional wheelie bars
sexy
baller status
thanks guys
71 nova
sexy
baller status
thanks guys
Re: couple questions plus 500 hp monster pics (Btothe3rdDegree)
Id contact the engine builder, order new rings, and do it all over again.
It could have been worse (bearing failure).
Also what was your timing at?
even if you contact the engine builder he will not do anything. He will blame it on your tunning.
something different
1 Post
the rings might be ok, but probably not.....
was the engine completely warmed up when you did the test?
was the throttle wide open when you did the test?
were all the fuel injectors unplugged, or was the ecu unplugged?
what compression is the engine supposed to be? if its in the 8's, 150-165 should be good...
but that 90 is a bad number...but not undriveably bad.. that ring set might not be seated that well. i've heard of people actually pulling the head and scuffing the cylinder lightly with a scotch brite pad, and "re-breaking" in the engine...and sometimes it works..
good luck..
good luck..
Re: (redzcstandardhatch)
the engine was warm and it was at full throttle, the weird thing is in never ever blow smoke, the first time it did blow smoke was after i put oil in the cylinder
something different
1 Post
if it runs good, doesnt smoke, and is fun to drive, just drive it.
take another compression test reading in 5000 miles or so.... it might be fine.
if your gonna re-ring it, wait a while IMO....see if it seats itself well. if its running fine, just roll with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">if it runs good, doesnt smoke, and is fun to drive, just drive it.
if your gonna re-ring it, wait a while IMO....see if it seats itself well. if its running fine, just roll with it. </TD></TR></TABLE>
thats what i was thinking but i want to turn up the boost and get it tuned i dont know if i want to do that with bad rings
Re: (urbansi)
is there anyway to tell if it is the rings besides pulling it apart? the head was completely rebuilt so i would hope it isnt a bent valve, could it need a valve adjustment?
Re: (sikciv666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 »</TD></TR><TR><TD CLASS="quote">i really have no answer for yah, but that car is ****** sick!!</TD></TR></TABLE>
Re: (Btothe3rdDegree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree »</TD></TR><TR><TD CLASS="quote">is there anyway to tell if it is the rings besides pulling it apart? the head was completely rebuilt so i would hope it isnt a bent valve, could it need a valve adjustment?</TD></TR></TABLE>
bad rings one cylinder will have a really off cp # from the rest, 2 you may see blue smoke come out the tail pipe(burning oil). or if you dont see blue smoke which you would, it would be just consuming lots of oil.
Do a leakdown test. Fill each cylinder w/ compressed air. And listen to where the leak is coming from.
If the valve is opening at the wrong time it will cause a bad compression reading. Try the valve adjustment. Get a feeler gauge and check each cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree »</TD></TR><TR><TD CLASS="quote">the engine was warm and it was at full throttle, the weird thing is in never ever blow smoke, the first time it did blow smoke was after i put oil in the cylinder</TD></TR></TABLE>
is that is the case you might have a blown headgasket.
does it make any noise when you listen to it idle. like an exhaust leak noise.
i had a low comp problem with my 5.0 and the headgasket was blown and venting to the atmosphere.
Yes, you can drop in new rings with the motor still in the car. If you're doing it with someone that knows what they are doing (read: is familar tearing down your motor), it can be done in a day. FYI it takes me about 2 to remove a b-series cyl head and I'm not rushing so it's no big deal.
i ♥ my honda
Global Mod
Global Mod
Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">Nice, I got a 68 stang running 11.24@121mph on a 200shot. Ill try to post pics of it.</TD></TR></TABLE>
PLEASE DONT
Is this the first compression test you have done since the build? I sure hope not!
How about a leak-down test? That would be what I did before I went any further.
PLEASE DONT
