do i need a MAP with hondata
Old May 16, 2005 | 09:53 AM
spooledu's Avatar
Default do i need a MAP with hondata
i am getting Hondata S200b with RC peak/hold low imp. 550cc injectors, on a P06 ecu, and i was wondering if i needed an Fuel pressure regulator, and a upgraded map sensor, or will i be able to use my stock MAP. thanks.
this is in an accord, that is why i am using Peak/hold injectors due to the resistor box.
-jeremy
Old May 16, 2005 | 09:59 AM
ITR981002's Avatar
Default Re: do i need a MAP with hondata (spooledu)
If you want to run more than 11psi, you'll need a different map sensor.
Old May 16, 2005 | 10:20 AM
dennis's Avatar
stock FPR should work fine. I currently use a P06 in my accord with Crome. I do have a B&M regulator, but it's set pretty close to stock. The only reason I bought it was to raise pressure a little bit when I went to higher compression pistons before I put the p06 in.
BTW, I'm sure you have this covered, but just in case, keep in mind that you have to swap EGR and O2 heater wires:
per hondata:
"94 and 95 Accords have EGR (A11) and the O2 heating (A6) reversed and must be rewired"
turbosi03
May 21, 2003 06:00 PM
RyanAutry
May 17, 2003 09:53 AM
Anubyss
Oct 18, 2002 05:35 AM
Mr. Vapor
Sep 19, 2002 06:00 PM
