Peakboost manifold w/38mm Tial
BCICAN
You think the peakboost manifold with a Tial 38 would be sufficient for 500-ish whp?? By sufficient I mean no spikes/creeps/unwanted variations in boost. Just didn't know if the 38mm could handle like 24 give or take a few psi
Re: (Makdaddynuge)
for a 450+ power goal, i would recommend going with the 44mm wastegate on the PeakBoost manifold.
we've actually had problems with the 38mm wastegate being overduty'd with the flow characteristics of a worked honda head. 1 case was with a Portflow head and a couple with the Endyn heads(which flow huge cfm).
the PeakBoost manifold is available with the 44mm wastegate for no extra fee, besides the purchase of the larger 44mm gate.
hope this helps
hope this helps
BCICAN
Re: (PhoenixTurbo.com)
Next question: same thing...38mm on a rev hard (the peakboost is not AC compatible ) Sooo if I use those two, how would I know if I am "over-dutying" the wastegate? I do plan on go with the FR ac manifold w/ a 44mm, but just not right now.
k9n
02-03-2009 05:09 PM
