wastegate - Internal-VS-External
Old May 16, 2005 | 02:04 PM
Dual_Phart_cans's Avatar
Default wastegate - Internal-VS-External
What are the pro's and con's of the two? tia
Old May 16, 2005 | 02:11 PM
1Bar GSR's Avatar
Default Re: wastegate - Internal-VS-External (Dual_Phart_cans)
internal < external
Old May 16, 2005 | 02:17 PM
yes but give me details =]
Old May 16, 2005 | 02:19 PM
lalspeed's Avatar
not to sure my self.........but if youre i ricer like me then youll love the way the external sounds when it cracks open
Old May 16, 2005 | 02:31 PM
DragSource's Avatar
IMO - they both work fine.
They both do the same thing. . .
Old May 16, 2005 | 02:43 PM
beepy's Avatar
Internal wastegates are just simple and cheap if the turbo you bought came with it. It is easily adjustable with a boost controller. You don't have to worry about plumbing up a dumptube. Etc. They are flow limited but even then, a standard .48 A/R T-3 with internal gate comes on 2.8 liter engines and don't have problems.
External wastegates can usually flow a lot more because they have much larger valves. Thus they are preferred in higher boost and flow applications. They are also much more expensive, more prone to failure, and may be more difficult to fit into your engine bay. They are adjustable by either different springs, external adjustments, or boost controllers.
_entropy's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">IMO - they both work fine.
They both do the same thing. . . </TD></TR></TABLE>
Externals just do it better with less chance of creep.
Old May 19, 2005 | 08:13 AM
DragSource's Avatar
The internal/external part of it doesn't make a bit of difference man. It's the size of the valve and inlet/outlet that make the difference.
If your internal gate had the same specs as your external gate it wouldn't make a bit of difference.
Some turbo's have internal w/g upgrade options.
Old May 19, 2005 | 09:03 AM
TurboGoKart's Avatar
Default Re: wastegate - Internal-VS-External (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote"> more prone to failure, </TD></TR></TABLE>
Can you elaborate on that? I've never had any "failure" problems with my Tial. It works better than any internal gate, and holds boost more solidly than any internal gate I've ever seen. They are not more prone to failure.
Old May 19, 2005 | 09:24 AM
DragSource's Avatar
I've read several reviews from Tial users with ripped diaphrams, and problems with the gate doing odd things as a result of running race gas w/ the wrong type of spring.
They're not "unreliable" - they just have problems from time to time like every other part.
Old May 19, 2005 | 09:26 AM
maybe that dude was thinking like . . . . internal w/g's come from factory so its not gonna mess up, but external wastegates are usualy aftermarket so say some newbert buys an external and installs it and ***** up . . . i guess that would make external more prone to failure, but ide assume if u installed it right, it'd work just fine
Old May 19, 2005 | 10:45 AM
DragSource's Avatar
I have heard more horror stories about the Deltagate than any other w/g.
Old May 19, 2005 | 10:50 AM
redzcstandardhatch's Avatar
something different
i havent, i've heard stories about the MANIFOLD deltagates seem to be always mounted on, ones where the gate comes off of only one runner..
on high HP cars, this is a bad design. my deltagate is great. i plan on upgradeing eventually, but i'm not sure what i will go to.
Old May 19, 2005 | 12:00 PM
mike1114's Avatar
Default Re: (redzcstandardhatch)
deltagate = crap, will have problems.
Tial = good, can't go wrong
Difference between external vs internal wastegate is an internal wastegate will start to open from the force of the exhaust gas before you get to your desired boost level, thus causing you to take longer to spool up to your desired boost level.
External gates can be held closed via boost controller to only open up once it hits a desired psi level. I don't know for sure, maybe internal gates can do this too...
Old May 19, 2005 | 12:14 PM
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">deltagate = crap, will have problems.
Old May 19, 2005 | 01:53 PM
powerls's Avatar
Internal gates can do that too. Many people look down on internally w/g setups, and most of them drive hondas. Mitsu and Nissan guys will swear by internally gated turbos. It is cheaper, and easier, granted the flow characteristics will not be as great, but it is still pretty good. The HKS drift silvia is internally gated and runs about about 1.5 bar. But if you are going for big power, you will need a external w/g. Choose wisely!
Old May 19, 2005 | 02:07 PM
93supercoupe's Avatar
Default Re: (powerls)
So external gates are good for High boost/high flow and internals are good for low boost, simplistic setups.
All I know is that my turbo MX6 has been internal gated for 250,000 miles.
V-SPEC 1
Feb 19, 2013 07:43 PM
Unphzd
Jul 8, 2011 10:14 PM
TannerCB
Apr 9, 2006 09:03 AM
KURUPTinc
Jul 12, 2005 01:04 PM
Broken Gearbox
Jun 8, 2003 02:12 PM
