D15b ninjas!!!
Old May 17, 2005 | 06:05 PM
1boostedcivic's Avatar
Default D15b ninjas!!!
there is hope for us!!!
http://www.d-series.org/forums...20921
"After some research and some contacts as well as Makku's research the D15B shares the same exact rod as a Z6. The difference lies on the cranks main bearings (USDM D15B7 journal size). Eagle rods meant for a Z6 WILL infact work in a D15B. The pistons however will not. Now, with a Vitara piston they do work. There are 3 people that I know of using Eagle (Z6) rods along with the Wiesco GX (forged vitara equivilent) in their D15B's. A Vitara piston is dished and due to the pin placement it gives a Z6 a rather low compression ratio. In a D15B they will be about perfect at around 9.0:1 with a thicker .043 headgasket. I do have one concern and that is the actual Vitara piston diameter. All Data states it as 74.98mm not a true 75mm. If you need to do an aggresive hone they will not work because of clearences from the piston to cylinder wall. If the block is in good shape they should work fine as many people have found. We will see."
Old May 17, 2005 | 07:31 PM
slywfbpsi's Avatar
Default Re: D15b ninjas!!! (1boostedcivic)
this info is already known.
Old May 17, 2005 | 08:01 PM
Tad's Avatar
Tad
Default Re: D15b ninjas!!! (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">this info is already known.</TD></TR></TABLE>
haha yeah but there was that one goofball who refused to believe it
hahaha
Old May 17, 2005 | 08:08 PM
sorry if im late on this but i havent been on honda-tech for 6 months. last i knew we were still trying to figure out if they would work. lol.
Old May 17, 2005 | 09:03 PM
Calvinator's Avatar
If the cranks main bearing sizes are different, then how would they be able to use eagle rods? Would you have to use a d16 crank? still confused over this...
Old May 17, 2005 | 09:07 PM
Tad's Avatar
Tad
Default Re: D15b ninjas!!! (xtremeazian)
you have to use the proper sized bearings
Old May 17, 2005 | 10:39 PM
Sinner's Avatar
so is the cam on the d15b better than the z6?
Old May 17, 2005 | 11:35 PM
DRIVENRacing's Avatar
boshina casa
Old May 17, 2005 | 11:37 PM
Tad's Avatar
Tad
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">so is the cam on the d15b better than the z6? </TD></TR></TABLE>
yes but if u want to use one in a z6 you'll need an adj camgear cuz the deck heights r diff
TAZ95
Jul 14, 2011 08:14 PM
90crxdriver
Jul 1, 2009 11:49 AM
xxiong88
Feb 17, 2008 07:10 PM
mattie_96
Oct 8, 2006 06:18 PM
civicdust
Jan 14, 2005 04:24 AM
