Car boggs and backfire at high boost!!!
Old May 17, 2005 | 07:05 PM
Bimmerman's Avatar
Default Car boggs and backfire at high boost!!!
Right now I am running the blue box and injectors, and in high boost 8-10 psi the cars starts to backfire, bogg, and loose power, should I siwtch to fmu with missing link, I have this as well would it run better? I all so have a walbro fuel allready installed. If I do go with FMU do I need to adjuster dist. to retard timing? if so don't I turn the dist clockwise for retard?
Old May 18, 2005 | 05:22 AM
teal_deal's Avatar
Default Re: Car boggs and backfire at high boost!!! (Bimmerman)
I had the same problem with my car get rid of the box and no fmu run a chipped computer, i did it and my car runs mint now.
Old May 18, 2005 | 06:36 AM
maddog20's Avatar
You maybe exceeding the limits of your MAP sensor. Try running 7-9 psi and see if it happens
Old May 19, 2005 | 08:28 PM
spoolingb20's Avatar
Default Re: Car boggs and backfire at high boost!!! (maddog20)
belive i ran into the same prob along time ago and turning it down fixed it until i was able upgrade
Old May 19, 2005 | 09:23 PM
used2baracer's Avatar
Default Re: Car boggs and backfire at high boost!!! (spoolingb20)
YOU ARE RUNNING LEAN I just had the same experience on my LS. I thought it was the map sensor or injectors, but after switching map with another and adjusting tps voltage, I had the same problem. The problem was I ran my car with a basemap because I was procrastanating on tuning, well... I finally hooked up the wideband, and right before it popped/backfired, I was at 17 -18:1.... LEAN!!!! Tuned the car and it feels like a dream. Anyway, 99% that's your problem... ps, get some real engine management!!!
Old May 19, 2005 | 11:58 PM
0bd1_Kanobe's Avatar
greddy blue box run at a set psi(6-7) and you can not go past that. I bet if you turn down the boost to 7 psi it would run good......Soichiro Garage 7
hybridracer504
Mar 25, 2009 09:01 PM
nicktagz
Sep 25, 2006 10:49 AM
evilsolb16
Sep 12, 2005 06:42 AM
turboegg
May 2, 2003 04:32 AM
KoRE
Sep 3, 2002 10:05 PM
