Built H22 Compression numbers?
Old May 17, 2005 | 06:31 AM
Pikachu's Avatar
Default Built H22 Compression numbers?
My H22 build is complete. It was tuned and driven on for about 60-100 miles. The compression numbers are 170 across. Should these numbers be higher or about right? Here's my setup:
GE HD Sleeved H22A4 87mm
GE Headgasket
CP Pistons 9:1
Pauter Rods
Stock head, everything else stock. Is 170 about where it should be? The car was tuned immediately according to Earl's recommendations. Thanks guys.
Old May 17, 2005 | 06:53 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Built H22 Compression numbers? (Pikachu)
Sounds a tad bit low but if they're all the same then you should be good to go.
Old May 17, 2005 | 08:59 AM
graphic's Avatar
Default Re: Built H22 Compression numbers? (White Smoke)
my numbers on my motor 87mm bore w/ 9:1 comp. via JE pistons are 187psi-190psi across the board..w/ a less than 2% leakdown
numbers might be alright because of consistency..
but it wouldn't hurt to do a leakdown...
Old May 17, 2005 | 09:30 AM
Pikachu's Avatar
I was told that the numbers should gradually go up. I only drove it for a minimal amount of time so maybe the rings haven't completely seated yet.
Old May 17, 2005 | 09:39 AM
Drag_On's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">I was told that the numbers should gradually go up. I only drove it for a minimal amount of time so maybe the rings haven't completely seated yet. </TD></TR></TABLE>
Rings seal way faster than you think they do..
If you broke it on the dyno -- then the rings are sealed (if they ever will be). Numbers look a bit low - but compression tests can vary from conditions to procedures etc. Consistency is a good sign. Try a leak down - if its good, run another compression test.
Old May 17, 2005 | 09:41 AM
Muckman's Avatar
Moderator in Chief
They will, dont worry. 100 miles isnt very long. I logged my compression numbers and by mile 250 they were 75% of maximum and gradually increased to full 100% compression rest over the next 500 miles.
Old May 17, 2005 | 09:46 AM
Pikachu's Avatar
It was street tuned and it wasn't broken in hard. I had it going with flucuating rpms. I didn't go nuts and hit redline though.
Old May 17, 2005 | 09:47 AM
john d
Guest
Posts: n/a
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">They will, dont worry. 100 miles isnt very long. I logged my compression numbers and by mile 250 they were 75% of maximum and gradually increased to full 100% compression rest over the next 500 miles.</TD></TR></TABLE>
did you break it in n/a or with boost?
i have a pretty similar set up besides, 89mm, rollerwaves pistons,manley rods mine compression is 210/205/208/210
when i first broke in the motor n/a it was 210/210/210/210
Old May 17, 2005 | 07:37 PM
Pikachu's Avatar
N/A of course. I will soon see what happens.
Old May 17, 2005 | 09:56 PM
Muckman's Avatar
Moderator in Chief
I think he was asking me. Broke it in NA using Motoman's guidelines.
codyh
15
Mar 26, 2012 09:18 PM
crxvtecturbo
Jan 15, 2005 06:28 PM
kwik93si
Jul 9, 2003 12:04 PM
DSGB.
Dec 24, 2001 08:55 PM
