Boost activated exhaust cut outs?
Old May 17, 2005 | 06:55 PM
vtec.dc2's Avatar
Default Boost activated exhaust cut outs?
i couldn't find anything on this. all i see is electronic cut out via switch, but is there anything that opens automaticaly as soon as it sees a set boost level? say 0-5psi? so while driving you don't have to worry about switches/buttons
Old May 17, 2005 | 07:02 PM
Bimmerman's Avatar
Default Re: Boost activated exhaust cut outs? (vtec.dc2)
yes check out http://www.atpturbo.com they have them, they are boost activated
BlueShadow's Avatar
How about wiring it in to your TPS instead? wire it so that when the TPS goes over a certain voltage the cutout would open? An electrical switch would probably be easier to setup then a boost activated switch.
EDIT: if you look on atpturbo like bimmerman suggested you wana look for the hobbs switch. I believe that's the same type of actuator you see on internal WG's. I dunno how you would set it up to a cutout though. Aren't e-cutout switches on/off? IMO a hobbs switch might not be the best to use for that.
Old May 17, 2005 | 08:04 PM
adseguy's Avatar
Default Re: Boost activated exhaust cut outs? (BlueShadow)
Idon't understand why people like those so much. Half the reason you want an e-cutout is so you get quicker spool. Well if it opens after you develop boost you loose that advantage. Although, you will see nice gains in top end the development of power won't be as good as say an e-cutout on a switch or TPS
Old May 17, 2005 | 08:12 PM
Quad-Damag's Avatar
Default Re: Boost activated exhaust cut outs? (adseguy)
don't get that ATP pos
it's a waste of money and will brake on u TRUST me
seen it brake 1st hand. it's not even great, doesn't open and close right at all
wait for the 2ed gen **** to come out
atp is working on a new better one
TehGhett0P1mp
Jan 7, 2009 09:34 PM
civicboy96
Engine Management and Tuning
Jul 9, 2008 05:28 PM
2ltrsnailpwr
Nov 27, 2003 05:57 AM
speedworks
Aug 14, 2003 09:05 PM
ElectronMan
May 6, 2003 01:20 PM
