Finally Tuned, numbers inside
Old May 17, 2005 | 10:26 AM
94lsboost's Avatar
Default Finally Tuned, numbers inside
B18c1, stock head - stock sleeves .030 over, 9.1 cp pistons, eagle rods, blockguard
t3/t04e 13 psi, hondata, rc 550's
The car was on the dyno the better part of the day, ended up making 15 or so dyno runs, and by the time I was ready to turn the boost up, it wouldnt hold more than 13 psi. I'm assuming it's a problem with the wastegate spring, or diaphram. Anyway, here is the sheet for 13 psi.
I was hoping for 360-370 at 16 psi, so but I guess I'll run it like this for a while, then try to figure out the boost problem. The Timing is conservative, and we didn't even touch the cam gears yet (of course they may or may not help).
Old May 17, 2005 | 10:33 AM
rhd's Avatar
rhd
not bad man! good luck with uping the boost, i'm sure you'll reach your goal!
Old May 17, 2005 | 10:35 AM
Lmgrcivic's Avatar
Default Re: (rhd)
pretty nice numbers, hoping to get mine tuned soon
Old May 17, 2005 | 10:38 AM
JDMisGOOD's Avatar
Default Re: (Lmgrcivic)
lookin good!
Old May 17, 2005 | 10:55 AM
c1civic's Avatar
nice numbers, bump for a local
Old May 17, 2005 | 11:03 AM
ITR981002's Avatar
Default Re: Finally Tuned, numbers inside (94lsboost)
How much timing?
Old May 17, 2005 | 11:08 AM
94lsboost's Avatar
Default Re: Finally Tuned, numbers inside (ITR981002)
Thanks fellas, I don't remember on the timing. I looked at so many fuel and timing tables while it was on the dyno, it's all a blur. I was thinking like 21 degrees was the most, but that may be totally wrong. I can't say for sure. I will find out though...
Old May 17, 2005 | 12:24 PM
Rod.'s Avatar
nice numbers
Old May 17, 2005 | 06:29 PM
94lsboost's Avatar
Default Re: Finally Tuned, numbers inside (redturbocivic)
Thanks I'm happy, for now....
Old May 17, 2005 | 06:38 PM
Dunc's Avatar
BCICAN
Looking good man....give me about 3 more weeks and then I want to run with you
Old May 17, 2005 | 06:39 PM
meltman1234's Avatar
Damn, nice numbers
I wish my curve was that smooth
Old May 17, 2005 | 06:55 PM
Tad's Avatar
Tad
Default Re: Finally Tuned, numbers inside (meltman1234)
cool,
300whp is good stuff,
and sounds like theres more to bad had once u work out whatever was
holding ur boost back.
but it sounds funny, if you were on the dyno the better part of a day,
how come only 15 runs?!?
I had my car tuned for 2 hrs, and they did around that many runs.. maybe even more.
Old May 17, 2005 | 11:37 PM
Dunc's Avatar
BCICAN
Default Re: Finally Tuned, numbers inside (Tad)
If I'm not mistaken I believe he was having issues getting everything to work right (piping blowing apart).
Old May 18, 2005 | 06:30 PM
94lsboost's Avatar
Default Re: Finally Tuned, numbers inside (Dunc)
We thought we had a piping problem, turned out to be a boost cut in hondata that we overlooked. It was on the dyno for that long b/c the emulator was down and we were burning chips, Rick took his time and did an awesome job
Old May 18, 2005 | 06:37 PM
1158's Avatar
Nice numbers
Do you happen to know what your duty cycle on the injectors was?
Old May 18, 2005 | 11:29 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost &raquo;</TD></TR><TR><TD CLASS="quote"> It was on the dyno for that long b/c the emulator was down and we were burning chips, </TD></TR></TABLE>
oooh, yeah that would take a while
Old May 20, 2005 | 10:17 AM
94lsboost's Avatar
Not sure on the duty cycle, they can't have a whole lot more in them, maybe 30-40 whp.
Old May 20, 2005 | 12:45 PM
B18Flip's Avatar
what were the specs on the t3/t4e?
Old May 23, 2005 | 06:55 AM
94lsboost's Avatar
Default Re: Finally Tuned, numbers inside (B18Flip)
.6 cold side, hotside is unmarked... 57 trim...not sure of a/r..
gotta get 3 more psi and some more timing, already feels slow
masterEF
Nov 10, 2009 05:56 PM
Running925
Apr 10, 2007 10:03 AM
kameleon23
Aug 23, 2005 08:53 PM
elpiar
Aug 2, 2005 08:41 AM
echo999
Dec 31, 2002 11:28 AM
