overheating, only after long (45+ minute) drives
so my car coolant gauge usually stays horizontal for most of my drives...
recently i drove a 2.5 hour trip somewhere and the needle would stay horizontal, but would rise once i got stuck in some traffic.
it would start to rise while I inch up during the traffic jams....
the needle would rise up to the 10 o'clock position, but never went past that...
i blasted the heater and it brought it down...
no coolant or oil mixture problems...
Radiator fan kicks in (b18turbo slimline fan) that was installed a couple weeks ago, but this problem came up this past weekend...
any thoughts on what i can do? I plan on raising the mounts on my hood to help dissipate heat (even though i hate how that looks)
Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Radiator heat soaking? </TD></TR></TABLE>
possible, especially since it only happens when you are in traffic...
how's your oil temp while all this is going on?
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">possible, especially since it only happens when you are in traffic...
how's your oil temp while all this is going on?</TD></TR></TABLE>
i don't have any oil temp gauges, just oil pressure....
Re: overheating, only after long (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">make sure the fan is set up the right way, puller or pusher.</TD></TR></TABLE>
its hard to tell exactly but the way i can tell is, when the fan kicks on, i feel hot air blowing when sticking my hand beind the fan...
Re: (utahbmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahbmx »</TD></TR><TR><TD CLASS="quote">Did you check to see if you have a sticky thermostat?</TD></TR></TABLE>
im gonna replace it cuz its long overdue... but thought this was quite strange...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">what raditor are you running? stock?</TD></TR></TABLE>
i'm running stock, but may invest in a better radiator (only if its necessary)
Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Did you recently drain and refill your coolant system? You most likely have air in the system.</TD></TR></TABLE>
nope
nope
Re: overheating, only after long (SOHC_MShue)
I doubt its the radiator. I drive my car wherever and get shafted with traffic a lot, and I NEVER have had an overheating problem.
Dude just put a nitrous sprayer on the radiator, duh
Do you have enough coolant? Is there a leak anywhere?
I would check thermostat, and radiator cap first.
if that doesn't work try driving off the grand canyon, you'll get all the air you need to cool your water down plus you wont have the run the heater anymore!
As a quick fix you could open your sunroof, keep your other windows closed, turn the heat on full blast toward your head, turn the side vents off, and direct the 2 vents blowing air straight of of your sunroof. I drive like this 24/7, rain, snow, shine, etc
Re: overheating, only after long (Boltz)
i was having overheating problems too, was happening only when i would boost for a while or get stuck in traffic, my reservior would overflow. turned out a complete coolant flush fixed the problem, no more being scare of traffic jams for me. so give it a shot, if you havent done so already.
pyrojeff
10-21-2019 09:50 AM
Monotremata
05-18-2011 05:21 PM
spock_rocker
06-06-2005 03:32 PM
