which wastegate is better tial 38mm or 44mm need opinion
Re: which wastegate is better tial 38mm or 44mm need opinion (boostedeg22)
Better is really subjective. I hve the same turbo and I went with a 44mm. I run my car on the street and want to be able to bleed off boost so I can run low boost hence the larger wastegate.
Re: which wastegate is better tial 38mm or 44mm need opinion (oxSLEEPERxo)
I am running the T3/T67 HO from Full-Race and I am running the Tial 44mm wastegate and I think that would be the better one for you
i ♥ my honda
Global Mod
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">seems like ur hp goal is going be high, i would suggest 44mm</TD></TR></TABLE>
I agree
I agree
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg22 »</TD></TR><TR><TD CLASS="quote">geoff from full race told me 38 is to small.what manifold are you running?</TD></TR></TABLE>
too small in general or for his app?
1 Post
Re: which wastegate is better tial 38mm or 44mm need opinion (turboedc2)
A smaller wastegate is better for higher boost, and a larger one for low boost. If you want high boost levels you don't need to release very much pressure....
The bigger the wastegate the better(to a certain point) with a big turbo... I have a t70 with a 38mm gate with 10psi... The lowest boost I can run is 15psi because the gate bleed off enough exhaust.
Re: which wastegate is better tial 38mm or 44mm need opinion (Hawkze_2.3)
good info so if i have the 38 and i plan on upgrading some things it deff can handle all the boost i can throw at it?
Re: which wastegate is better tial 38mm or 44mm need opinion (spoolingb20)
Read this thread I made in the Drag Racing forum. There is some very good information here, but keep in mind that all setups will react differently.
https://honda-tech.com/zerothread?id=1227346
chris
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 »</TD></TR><TR><TD CLASS="quote">not sure which one to buy for a t3\t67</TD></TR></TABLE>
44mm
44mm
Re: (BoostedSiRhc)
more of decision how you want to control boost. i would get the largerst i could afford if you plan on running low boost with very large turbo
J.nguyen
10-11-2006 12:02 PM
