Something is wrong, but what???
Old May 17, 2005 | 08:45 AM
goose21's Avatar
Default Something is wrong, but what???
My car stalls when i just let it idle. And when it idle's @900rpm i have a very low vacuum between 14-15. And it sounds like's it misfires. I've done a compression test and this whas the result.
1 150psi
2 95psi
3 100psi
4 100psi
Then we did a leak down test and then this where the results
1 90%leak
2 75%leak
3 80%leak
4 80%leak
But when i drive the car it runs fine, it doesn't smoke, it still fast(drove ,5sec faster then when the car was oke on the 1/8 this weekend)
Only in low rpm's it runs bad. So what could it be???
Old May 17, 2005 | 08:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Something is wrong, but what??? (goose21)
was the compression test done at WOT? Those numbers sound way low.... all of them, and the leakdown is horrible. sounds like your rings are ****..
Old May 17, 2005 | 08:52 AM
goose21's Avatar
Default Re: Something is wrong, but what??? (wantboost)
Yes the compression test whas done on WOT and a warm engine.
But wouldn'd my car smoke like hell if my rings are gone this bad??(it doesn't smoke at all, not even a little)
thanks jose
Old May 17, 2005 | 08:59 AM
veggiemaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">was the compression test done at WOT? Those numbers sound way low.... all of them, and the leakdown is horrible. sounds like your rings are ****.. </TD></TR></TABLE>
it sounds like you have some serious blowby. and it wouldnt necessarily smoke. I had a cylinder in a b18a that was pretty shot and I didnt have any noticible burn. But also, have you checked the basic things? like your plugs, how are they? you could also be running way lean.
wantboost's Avatar
Who is Mr Robot?
have you checked the cam timing? it could be off a little, that can affect numbers a bit
Old May 17, 2005 | 09:11 AM
goose21's Avatar
The plugs are good(light brown). And the cam timing also. I've also done a valve adjustment. Couldn'd it be that my valves are burned or something???
Old May 17, 2005 | 09:21 AM
wantboost's Avatar
Who is Mr Robot?
you could have mis-adjusted the valves... the reason it oculd be pulling shitty vacuum down low is because the valves arent opening or closing fully
Old May 17, 2005 | 09:28 AM
goose21's Avatar
That whas i thought. But i have done a valve adjustment sunday.
Modified by goose21 at 11:19 AM 5/17/2005
Old May 17, 2005 | 10:57 AM
goose21's Avatar
bump
allmotorsi04
Apr 1, 2006 05:08 PM
silverboost
Nov 8, 2005 01:01 PM
TurboJesse
Sep 17, 2003 08:22 AM
HondaUser
May 29, 2003 07:25 PM
gsr~hatch
Apr 17, 2003 03:19 PM
