want go past 3100rpm then boggs..
im guessins its a bad ecu or a bad obd1 conversion harness.timing fine. fuel pressure is fine. i got good vaccum.everything is grounded. only thing is im running greddy 310 on stock motor.i dont have stock ls injectors and my d16y8 injectors want work right in it i tried.any ideals. the motor is a b18b1 sitting in a 00 civic coupe. only mods is rods pistons and fuel pressure regulator. if that helps any
Re: want go past 3100rpm then boggs.. (SSBPGSR)
OT: SSBPGSR, everytime I read something you post I imagine Johnny Tran yelling it. It's quite amusing, thank you.
But yea check with your tuner and check all your timing and ignition maps. Is your CEL on?
Re: want go past 3100rpm then boggs.. (meltman1234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meltman1234 »</TD></TR><TR><TD CLASS="quote">OT: SSBPGSR, everytime I read something you post I imagine Johnny Tran yelling it. It's quite amusing, thank you.
But yea check with your tuner and check all your timing and ignition maps. Is your CEL on? </TD></TR></TABLE>
haha your welcome!
haha your welcome!
Re: want go past 3100rpm then boggs.. (DXK Eg)
its tuned for uberdata but i took the chip out just to see and it still boggs.when i first got the car started since the swap smoke came out of the ecu. thats why i figure its a bad ecu.yeah my cell is on but it want let me check it
Re: want go past 3100rpm then boggs.. (jdm.ej)
In limp mode because of the CEL. Get it fixed if possible, I don't know why it won't let you check it.
tslex
06-05-2004 11:51 AM
