how much boost on stock civic injectors?
im wondering how much i can boost with the stock civic inectors.Im trying to figure out why my safc2 dont respond well to my stock injectors under boost.
Re: how much boost on stock civic injectors? (project civic)
the computer sees posative manifold pressure and that throw's a check engine light and goes into limp mode
you're not supposed to hit boost with a stock computer and injectors; Thats a really bad and stupid thing to do; quit half assing and get some real management;
yes i do go into limp mode but i also have the missing link installed so theres no way the map will see positive pressure. I used my wideband and found out that under boost the a/f would lean out to 18. The safc is just for the meantime before i get Uber. Im assuming its the stock injectors that causing this. I previously had the dsm 450's installed but it ran like crap so thats why i went back to stock.
18:1 under boost is bad news; if you haven't broke something already it will break soon.
Get real management; go d/l crome or uberdata and set that **** up. Also research what to do for fuel managment; obviously you didnt do something right if your car wasn't running right with 450cc injectors
