Which ARP head studs to use?
Old Sep 4, 2005 | 12:51 PM
Jizzmaster Zero's Avatar
(banned)
Default Which ARP head studs to use?
I currently have a D16Z6 block with a D16Y5 head. ARP makes 2 sets of studs for D series, one for D16Z and one for D16Y. Does anybody know which ones would fit my hybrid application?
Old Sep 4, 2005 | 12:58 PM
1boostedcivic's Avatar
Default Re: Which ARP head studs to use? (Jizzmaster Zero)
whatever shortblock your using is the arp headstuds you will need to match your gonna have to go with the z6 ones. i just a did a built z6 block with d15b vtec head and the z6 arps headstuds worked fine
Old Sep 4, 2005 | 03:09 PM
(banned)
Default Re: Which ARP head studs to use? (1boostedcivic)
I was under the impression that it was the other way around; you use the head studs that match the head. Anybody else have some input?
Old Sep 4, 2005 | 05:30 PM
JDMCRX's Avatar
Yeah the Y8 studs i think 1 is just longer i forget ur gona need the Z6 ones
Old Sep 5, 2005 | 12:24 PM
(banned)
Default Re: Which ARP head studs to use? (JDMCRX)
bump
Can anyone confirm that you use the head studs that match the block, not the head?
Old Sep 5, 2005 | 02:52 PM
Jaker's Avatar
I bought D16Y headstuds to put my D16Y7 head onto my D16A6 block, and they were way too short. I ended up using D16Z6 studs, and had to run 4 extra ARP washers on the 2 studs at the back corners of the block/head. I suspect you will need to do the same. I think you need to match the studs to the shortblock but that's no garantee that it'll be a plug and play fit.
Old Sep 5, 2005 | 06:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero &raquo;</TD></TR><TR><TD CLASS="quote">bump
Can anyone confirm that you use the head studs that match the block, not the head?</TD></TR></TABLE>
Go with the z6 studs!!
Old Sep 6, 2005 | 10:45 AM
EnzoSpeed's Avatar
You have to buy the z6 studs plus 8 extra washers. The washers are about a buck a piece from ARP.
Old Sep 6, 2005 | 10:47 AM
EnzoSpeed's Avatar
Default Re: Which ARP head studs to use? (EnzoSpeed)
Read this thread
https://honda-tech.com/zerothread?id=1360338
The washers can be found on the ARP website. The ones you need are 10mm unchamfered with a 3/4" O.D.
Xemu
11
Aug 30, 2006 09:02 PM
EF9ZC
Mar 21, 2006 11:49 AM
JDMKid71
Feb 13, 2006 07:05 PM
Screaming
Feb 8, 2006 12:28 PM
spun Vtec
Dec 6, 2005 01:11 PM
