accord pillar gauge pod question.....
ok, im installing a boost gauge and a few other gauges in my 92 accord... im using the 94-01 integra pillar pod cause i was told it would fit.. my question is.. where the hell do you guys run your wires and stuff? do you just drill a hole in the dash or what? i thought about drilling a hole in the dash behind where the gauge pod would cover it but i dont want to hit anything under it.... thanks guys.... (the reason i posted in here is because i know most of you obvisly run a boost gauge and would know what is the best place to run the wires and lines and stuf)
Re: accord pillar gauge pod question..... (turboH22Aakkord)
I just looped them all through the dash so I could run the wires to the firewall before i put the pillar on. When you snap the auto-meter pillar to the OEM one you can kinda sandwich the wires inbetween. It looks tight, but it will fit. Oh and make sure you get those little push tab things right the first time, they are a bitch to get and recycle
Re: accord pillar gauge pod question..... (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv »</TD></TR><TR><TD CLASS="quote">I just looped them all through the dash so I could run the wires to the firewall before i put the pillar on. When you snap the auto-meter pillar to the OEM one you can kinda sandwich the wires inbetween. It looks tight, but it will fit. Oh and make sure you get those little push tab things right the first time, they are a bitch to get and recycle </TD></TR></TABLE>
kool man.. thanks..
kool man.. thanks..
turboH22Aakkord
09-06-2005 02:57 PM
travis
09-22-2001 01:00 PM
