wieco pistons
Old Sep 8, 2005 | 05:59 AM
B16EKHATCH's Avatar
Default wieco pistons
any one using wiesco pistons ?
how well do you like them?
Old Sep 8, 2005 | 06:17 AM
Dunc's Avatar
BCICAN
Default Re: wieco pistons (B16EKHATCH)
I used the 8.8:1's and they did just fine for 20,000miles with 375whp @ 14psi. But I can't comment how they would be with more miles as I am currently rebuilding now using a different piston/compression simple because my insatiable appetite for power was not being feed with 375 anymore.
wiseco gets a from me.
Old Sep 8, 2005 | 06:30 AM
200cs's Avatar
Ive got em...stock compression ratio for a type-r with boost. They work great.
Old Sep 8, 2005 | 07:19 AM
Turbo-charged's Avatar
Default Re: wieco pistons (200cs)
been running them all year
Old Sep 8, 2005 | 07:40 AM
1700anddroping's Avatar
Default Re: wieco pistons (Turbo-charged)
i use them in a b20 vtec i built and we are spraying 400 YES I DID SAY 400....car ran 7.18 and spinning almost to the 330....car definitely has 6's in it...just have to get a bigger slick........
harv
Old Sep 8, 2005 | 05:34 PM
dome's Avatar
Default Re: wieco pistons (1700anddroping)
making 650 with them. like them alot. skirts come coated and light as hell. just watch the oil squirters if using a ls crank.
Old Sep 8, 2005 | 05:38 PM
LVB18Civic's Avatar
Default Re: wieco pistons (dome)
Is there oil squirter clearance issues with these pistons on a GSR? or only LS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">just watch the oil squirters if using a ls crank.</TD></TR></TABLE>
Old Sep 8, 2005 | 05:46 PM
non-VTEC's Avatar
Default Re: wieco pistons (LVB18Civic)
only in the B18C block is there oil squirter clearence issues....the LS block is fine.
im using wiseco pistons.....
Old Sep 8, 2005 | 05:49 PM
*Boostwerks*'s Avatar
I would use Wisecos over any forged piston. Reasons...Offset wrist pin (like OEM), they come coated, and Import builders has reported that the clearances are better than most of the other manufacters.
Old Sep 8, 2005 | 07:26 PM
SOHCmaster's Avatar
I plan to buy them or CP havent made up my mind yet.
Old Sep 8, 2005 | 08:00 PM
Boostfed's Avatar
New User
Wisecos are awesome pistons, I have ran three sets of them in my builds! Just FYI for people talking about the oil squirters above, when running Forged Pistons the oil squirters are no longer needed, you can get block off plugs from Golden Eagle to replace the squirters. Stock cast pistons need the oil for cooling the forged pistons do not
I sell Wisecos too also CP, JE, Arias all are good pistons
Old Sep 8, 2005 | 08:48 PM
careawholelot's Avatar
Default Re: (Boostfed.com)
wiseco
Old Sep 8, 2005 | 09:09 PM
MissLady's Avatar
Default Re: (careawholelot)
mine are still sitting in the box...theyve been that way for 2 years now
Old Sep 8, 2005 | 10:09 PM
Teglove2's Avatar
Wiseco is the best! Btw, I work for them!
Old Sep 8, 2005 | 11:57 PM
mochasi's Avatar
Default Re: (Teglove2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">Wiseco is the best! Btw, I work for them!</TD></TR></TABLE>
Old Sep 9, 2005 | 05:35 AM
200cs's Avatar
I had to adjust the squirters on my b18c5 block to clear the piston. Just a slight bend and has been working fine for over 2 years. I would leave them if possible. The extra lubrication/cooling can't hurt. just my two cents...
THESENUTZ93
Nov 30, 2014 05:39 PM
almostjdmeg
Oct 8, 2008 08:33 AM
recon23
Nov 6, 2007 04:50 AM
ekVtecPower
Jun 18, 2006 09:05 PM
granada_sun
Jul 2, 2003 12:52 PM
