GSR Head Repair
Old Sep 8, 2005 | 01:02 PM
Muckman's Avatar
Moderator in Chief
Default GSR Head Repair
Due to detonation one of my pistons broke apart resulting in damage to the head in that cylinder.
This is what the damage looks like:
Ive had several engine builders tell me the damage is cosmetic and it wont hurt anything. I am worried about hot spots leading to more detonation. However they tell me most of the dings are near the outside edge of the cylinder and are nothing compared to the large ridge on both sides of the chamber that is there from the factory.
What does everyone think?
Old Sep 8, 2005 | 02:08 PM
cubish's Avatar
Default Re: GSR Head Repair (Muckman)
it can be welded and resurfaced.. its not bad at all... ive seen headed with valves shoved in them sideways be fixed
Old Sep 8, 2005 | 02:09 PM
Muckman's Avatar
Moderator in Chief
Default Re: GSR Head Repair (cubish)
To weld and resurface it will cost me $400. The very same shop said its only cosmetic and its not nessecary. They told me to dremel it down.
Another shop wouldn't even quote me a price to weld and resurface it because they said it didn't need it at all. They said just leave it alone.
Old Sep 8, 2005 | 02:24 PM
non-VTEC's Avatar
hmmmm........its a tough call.......why not just tell the machine shop to weld it up, your willing to pay.....
Old Sep 8, 2005 | 04:48 PM
astig* DC2's Avatar
Default Re: GSR Head Repair (non-VTEC)
used GSR heads cost around that much...just a comment.,if i wre u ill just buy a used one thats working properly..that will save u time and it'll be a bit safer than having that repair...just and advice..
Old Sep 8, 2005 | 04:51 PM
b18bEKcoupe's Avatar
Default Re: GSR Head Repair (k4SP3R)
just buy another one and sell me that one
Old Sep 8, 2005 | 05:22 PM
BigMoose's Avatar
There is nothing wrong with that head, it does not need to see a TIG torch, period.
Just take a cartritdge roll and "smooth" the chamber. Don't try to get all the dings out, just smooth off the sharp edges that were formed when stuff hit it. You got away cheap. Enjoy it! ... there's not a thing there to stress about...
Old Sep 8, 2005 | 05:39 PM
Oyvind Ryeng's Avatar
Default Re: GSR Head Repair (BigMoose)
Am I seeing a crack in the bottom exhaust valve?
Old Sep 8, 2005 | 06:31 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">There is nothing wrong with that head, it does not need to see a TIG torch, period.
Just take a cartritdge roll and "smooth" the chamber. Don't try to get all the dings out, just smooth off the sharp edges that were formed when stuff hit it. You got away cheap. Enjoy it! ... there's not a thing there to stress about...</TD></TR></TABLE>
Thanks thats exactly what I wanted to hear!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">Am I seeing a crack in the bottom exhaust valve?</TD></TR></TABLE>
In the center of the valve? I think thats just a dark line on the surface. It doesnt look like a crack in person.
Old Sep 8, 2005 | 07:49 PM
RudeLude's Avatar
i do think that theres a crack between the two exhaust valves though, def. looks like one from the pic, might wanna check that out bro.
daniel
Old Sep 8, 2005 | 08:04 PM
Boostfed's Avatar
New User
Best person I know to repair a Honda head is Don Flores of DFE Enterprises (904)378-4480
I will find the thread where he fixed Mike Corvey's aka VtecKidd's head
Edit:Here it is
https://honda-tech.com/zerothread?id=1340676
Before Pics:
After Pics:
Old Sep 8, 2005 | 09:51 PM
vaporboy12's Avatar
Default Re: (Boostfed.com)
haha that nice work i wonder if he could of fixxed my old head
Old Sep 9, 2005 | 03:23 AM
cinq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Best person I know to repair a Honda head is Don Flores of DFE Enterprises (904)378-4480
Edit:Here it is
Before Pics:
After Pics:
From those pictures...they don't look like the same head to me.
Old Sep 9, 2005 | 05:02 AM
BoostedEG6's Avatar
Default Re: (cinq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq &raquo;</TD></TR><TR><TD CLASS="quote">
yeah I just looked closer at them and that is deffenitly not the same head!! if you look at the water jackets on the head you will see the one on the right has a long opening and then in the second pic it doesnt?
Old Sep 9, 2005 | 05:17 AM
drumking15's Avatar
i willin to bet its the same head...he just didnt take pics of the right side...it has similar valves and is the same style head...if you look closer youll notice in the 1st pic intake is on top and in the 2nd intake is on bottom....my guess is he just flipped the head around and didnt notice for the 2nd pic....so obviously its not the same cylinder but id bet the whole head floated some valves and he was just showing a comparision pic although i could be wrong
and muckman...personally id just clean it up a bit...and make sure when you tune it again you have idv cylinder fuel trims...cause obviously that cc is gonna be a lil different...slight drop in compression and swirl pattern...some minor compesation so take care of it
Old Sep 9, 2005 | 07:22 AM
Fkned's Avatar
I would just resurface the head ,it looks ok to me from the pics to run.
Old Sep 9, 2005 | 10:30 AM
astig* DC2's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">yeah I just looked closer at them and that is deffenitly not the same head!! if you look at the water jackets on the head you will see the one on the right has a long opening and then in the second pic it doesnt?</TD></TR></TABLE>
WAHAHAHA.... u got cought... those pics arent the same head...
Old Sep 9, 2005 | 12:48 PM
DRAGLS's Avatar
The head is fine,just get some sand paper and go to work
Zaraki
Jun 28, 2014 01:18 PM
Natural Aspirations
Apr 7, 2013 07:11 PM
Rosko
Welding / Fabrication
Nov 26, 2006 08:19 PM
SoCaLNaTIvE
Apr 24, 2005 09:21 AM
