Finally hit 11's, B18b LS Turbo , Low boost
well guys i ran my car tonight, at first i was upset because my MBC wouldnt crank up "at all" it would only run off the wastegate setting (10psi) and in 3rd and 4th be at 12psi. I was running my car full interioer (2400 w/ me) and open DP this time to get my big *** T4 spooled. But i'm happy w/ my results
60ft - 1.717
330 4.957
1/8 7.668
mph 89.81
1000 10.015
1/4 11.98
mph 114.56
11 second LS turbo on 10-12psi ! woohoo!
Bad news, On the way home i shattered ANOTHER ls oil pump, This CTR N1 is the blame i know it. Tomorrow im installing my new ITR pump and throwing the N1 away and putting my stock one back on!
for 11's !!!
Car: 1992 Honda Civic DX Hatch
Engine:
<U>Bottomend</U>
B18a
srp 9.5:1 pistons
Eagle rods
arp rod bolts
arp head studs
Moroso style oil pan
Stock Sleeves
<U>Head</U>
B18b
Ported & Polished by me
Stock Cams
STR intake manifold
Stock B18b TB
NGK 2step colder plugs w/ a .025 gap
<U>Turbo setup</U>
Inlinepro Cast Stainless Steel T4 mani
T4 T04E , stage 5 wheel, 60trim, 70ar, 3in Vband
37mm wastegate 10psi spring
rev hard 2.5" charge pipes
Greddy TypeS BOV
11.75 X 31 X 3 FMIC
Open (ID) 3" down pipe
RC440 cc injectors (Rail pressure 52psi)
Uberdata
Walbro255 intank HP pump
60ft - 1.717
330 4.957
1/8 7.668
mph 89.81
1000 10.015
1/4 11.98
mph 114.56
for 11's !!!
Engine:
<U>Bottomend</U>
B18a
srp 9.5:1 pistons
Eagle rods
arp rod bolts
arp head studs
Stock Sleeves
<U>Head</U>
B18b
Stock Cams
STR intake manifold
Stock B18b TB
<U>Turbo setup</U>
Greddy TypeS BOV
11.75 X 31 X 3 FMIC
Uberdata
Re: Finally hit 11's, B18b LS Turbo , Low boost (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper »</TD></TR><TR><TD CLASS="quote">well guys i ran my car tonight, at first i was upset because my MBC wouldnt crank up "at all" it would only run off the wastegate setting (10psi) and in 3rd and 4th be at 12psi. I was running my car full interioer (2400 w/ me) and open DP this time to get my big *** T4 spooled. But i'm happy w/ my results
60ft - 1.717
330 4.957
1/8 7.668
mph 89.81
1000 10.015
1/4 11.98
mph 114.56
for 11's !!!
Engine:
<U>Bottomend</U>
B18a
srp 9.5:1 pistons
Eagle rods
arp rod bolts
arp head studs
Stock Sleeves
<U>Head</U>
B18b
Stock Cams
STR intake manifold
Stock B18b TB
<U>Turbo setup</U>
Greddy TypeS BOV
11.75 X 31 X 3 FMIC
Uberdata
Impressive times and setup, but I am not 100% sure you should blame the pulley for the oil pump thing...I had an ls setup w/ 160k + miles with an unorthodox racing (1 ribbed crank race pulley) with over 150 dragstrip passes and massive street beatings, and never had one problem...Its funny I have seen some n/a oil pumps on bone stock motors fail at 130k + miles.... Who knows the real reasons why...
60ft - 1.717
330 4.957
1/8 7.668
mph 89.81
1000 10.015
1/4 11.98
mph 114.56
for 11's !!!
Engine:
<U>Bottomend</U>
B18a
srp 9.5:1 pistons
Eagle rods
arp rod bolts
arp head studs
Stock Sleeves
<U>Head</U>
B18b
Stock Cams
STR intake manifold
Stock B18b TB
<U>Turbo setup</U>
Greddy TypeS BOV
11.75 X 31 X 3 FMIC
Uberdata
Re: Finally hit 11's, B18b LS Turbo , Low boost (99lspwr)
via the trap speeds. its only making what .. 300-350
key here is .. TRACTION bet you don teven spin thru the gears do ya ?
Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Congrats man! Long time coming, glad you finally hit it </TD></TR></TABLE>
thanks man, it took some effort and several trips to the track but i made it! haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangerex04 »</TD></TR><TR><TD CLASS="quote">great stuff , gives me lots of hope on reaching my goal, yeah and dyno #'s?</TD></TR></TABLE>
was street tuned so I have no idea on what numbers, But according to weight and MPH id say last night i was makeing 280ish on 10-12psi range.
On 17 id say im makeing easy 340ish. I have no clue tho so I'll wait for my dyno numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">
Impressive times and setup, but I am not 100% sure you should blame the pulley for the oil pump thing...I had an ls setup w/ 160k + miles with an unorthodox racing (1 ribbed crank race pulley) with over 150 dragstrip passes and massive street beatings, aand never had one problem...Its funny I have seen some n/a oil pumps on bone stock motors fail at 130k + miles.... Who knows the real reasons why...</TD></TR></TABLE>
they say w/ boost makeing in the 300whp range the vibrations it gives off destroys the pump quickly. In my case... 2 pumps in 2 weeks
I'm installing my new ITR pump as we speak w/ my stock pully haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">you don't think the oil pump ruined anything?
awesome numbers. Pretty good 60'</TD></TR></TABLE>
As soon as i saw the light, I turned it off and coasted to the side of the highway. Gotta love AAA. haha Shouldnt of hurt anything tho i hope, wasnt on long enough to i believe. maybe a second or so.
Re: Finally hit 11's, B18b LS Turbo , Low boost (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">via the trap speeds. its only making what .. 300-350
key here is .. TRACTION bet you don teven spin thru the gears do ya ? </TD></TR></TABLE>
nope, No spinning. Something that is hurting me tho is my *** end tucking and my rear tires rubbing the wheel well's threw 1st, a lil threw 2nd and when i shift to 3rd. lol
And about the power, I have no idea how much it makes like it sits. But i'll find out soon thou
Based on having the same car/motor and weight, I would say at trap speeds of 114 mph would equal approx. 260 whp...
1 Post
Re: (JDM S1eeper)
wow what intercooler is this how did u fit in the car .. mine is about the same size and i'am having problems with it look btw what charge pipe are those ?
Glad to see you posting track times I would drop the oil pan and make sure everything is ok. If you caught it quick enough everything should be fine but I would just make sure Have you looked into a Fluidampr? I have one on my built B18b.
Re: Finally hit 11's, B18b LS Turbo , Low boost (hondaguyef)
If I could get slicks and yank a 60ft like that I'd be running 11s... Instead Im running 13s.. and just trying to hit 12s on street tires... @ 12psi on a stock B20... Nice timeslip, Im quite jealous! lol What was your total ignition timming?
Boost ownz....
Boost ownz....
very nice
are u getting ur vacuum source for the WG from the IM or turbo? Is there a difference where u get it from? cuz i have mine from the turbo to the wg
