Breather
Old Sep 4, 2005 | 07:02 PM
95boostedteg's Avatar
Default Breather
I need some help u guys. I am turboed and running an endyne catch can. The question is, what should i do with the valve cover line? should i put a breather on it or run a greddy catch can between the valve cover and back to the charge pipes? Please let me know. Thanks
Old Sep 4, 2005 | 10:00 PM
ZC1.8crx's Avatar
Default Re: Breather (95boostedteg)
email larry at endyn and ask him he is good with answering question.
Old Sep 4, 2005 | 10:46 PM
Default Re: Breather (ZC1.8crx)
actually, the endyn is already hooked up. I just need to know what should i do with the valve cover nipple.
Old Sep 4, 2005 | 11:58 PM
RogueWorks's Avatar
I had done a lot of research in the past on this topic and could never come to a clear answer. I simply put one of those little filters on it.
Old Sep 5, 2005 | 08:13 AM
nfn15037's Avatar
The valvecover and crank case share the same airspace, treat it as you would the crank case. I ran a 1/2 inch hose off the valvecover and Teed it into the upper hose going to the Endyn catch can.
DelSolMike
Aug 11, 2013 08:26 AM
Blue94Accord
Apr 19, 2012 08:01 PM
Tech-Nics
Jan 4, 2007 01:21 AM
swappedcx
Welding / Fabrication
Jan 3, 2007 10:38 AM
