AEM FPR DIAPHRAM DESIGN CHANGE??
I recently purchased a FPR diaphram b/c my old diaprham seemed to have a very slow leak when I hooked it up to a vaccum pump, I just picked up the new one and the design is much different, instead of there being a flat half sphere piece there is a large ballbearing, with no spring on the back of it unlike the old model. If anyone has seen this or even heard of this Id really appreciate it.
Re: AEM FPR DIAPHRAM DESIGN CHANGE?? (R6E6I6D)
Yes, they changed it. So, you bought the new diaphragm and that's it? If you have the old design, then you need to buy a rebuild kit, which includes new orifices as well.
Re: AEM FPR DIAPHRAM DESIGN CHANGE?? (USE2B16A)
shitty how much is that gunna run me>? and its really weird I vaccum test the diaphram and it always shows a leak but no fuel (from what I see gets past) could it be such a small leak its only fumes... and I also replaced the old diaphram after fiding out it was the wrong one and now after I shut the car off the Fuel pressure drops to zero instead of chillen like it used to, but I cant locae a leak down in teh fuel system.
Why don't you call AEM and see if they'll exchange the diaphragm since you got the wrong one? I think the rebuild kits are <$40. If there's a vacuum leak, and no fuel is getting past, then the leak is above the diaphragm.
can a small amount of gasket maker on the inside of the FPR fix this, I figure its worth a try and I think it is leaking right near the vaccum plug in... I already orderd an old style diaphram but I hear these are quite problematic and Its not a bad Idea to have it laying around....
