no boost help!!!!!
Old Sep 5, 2005 | 06:32 PM
hybrid_204's Avatar
Default no boost help!!!!!
i have no boost, first of all the turbo is a brand new percsion sc32 turbo, the turbo spools up making a swizzing sound with no boost the boost gauge does'nt go past 0 however the vacum works.. what should i check for. I am using rubber and silicon couplers and the pipes are 4 section, the intercooler doesnt leak i did a pressure test i am also using a cast iron manifold by rev hard and a wasgate by tial, and log type b.o.v by apex'i and a downpipe.. what should i check for ??? i have check my waste gate and even borrowed my friends waste gate which has been working on thier car.
thanks
Modified by hybrid_204 at 7:43 PM 9/5/2005
Modified by hybrid_204 at 7:44 PM 9/5/2005
Modified by hybrid_204 at 8:59 PM 9/5/2005
Old Sep 5, 2005 | 06:37 PM
marclar's Avatar
Default Re: no boost help!!!!! (hybrid_204)
make sure ur bov is shut when the cars idling.
you could try unhooking the hose to the gate and seeing if that changes anything.
the onlyt hing that cauzes no boost is.. leaks, bov being open, or wastegate opening too soon.
Old Sep 5, 2005 | 07:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: no boost help!!!!! (marclar)
And not having a downpipe, I didnt have one on my car and I would only build boost @ like 5k in 4th gear and it was only like 3psi, so if you dont have a downpipe of some sort... try that...
good luck
Blaze
Old Sep 5, 2005 | 07:58 PM
hybrid_204's Avatar
opps i forgot to metion that i had a downpipe as well
Old Sep 5, 2005 | 08:24 PM
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marclar &raquo;</TD></TR><TR><TD CLASS="quote">make sure ur bov is shut when the cars idling.
the onlyt hing that cauzes no boost is.. leaks, bov being open, or wastegate opening too soon.</TD></TR></TABLE>
bov is open at idle or while in vac for that matter. i didnt have a dp on my car and it built boost fine. sounds like a boost leak somewhere. check all your couplers to see if they have leaks. if you welded up some of your charge piping make sure they dont have any pinholes. also what kind filter are you running? if you have a sock or something on there haha take it off and go for a drive. good luck
1sic3dr
Aug 11, 2007 03:28 PM
spoon95eg
Jan 17, 2006 06:31 PM
crew08 (girlygirlracer)
Oct 13, 2005 07:58 PM
buddha1320
Jul 20, 2005 09:03 AM
eg6T
Oct 1, 2004 06:14 PM
