bkr7e-11, bkr7es-11, bkr7e
NGK bkr7e-11, bkr7es-11, bkr7e
what is the differences? im currently usin bkr7e-11 -V-power-
which one is recoommended for turbo cars?
i gots a b16a
i gots a b16a
Re: NGK bkr7e-11, bkr7es-11, bkr7e (boosted2cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam »</TD></TR><TR><TD CLASS="quote">2 steps colder wouldnt it be bkr9e-11?
anyone got a better answer?</TD></TR></TABLE>
yea, i had a brain fart there. actually you would want to go with a bkr7e-8 or 9. a lot of turbo guys run the bkr7e.
bkr7e-11 has different gap out of the box than the bkr7e....but are the same
making the bkr7e the better choice for the smaller gaps we run on our turbo cars
Both will work. After buying several sets of bkr7e-11 i like the bkr7e better since the gap is smaller out of the box -11s are a bitch to gap correctly you have to smash the groundstrap down.
Re: NGK bkr7e-11, bkr7es-11, bkr7e (Treblarefils)
Gonna bump this old thread....
What is the difference between the BKR7ES-11 and the BKR7E-11? What do the S stand for?
I couldnt get the BKR7E so I got the S-11's for my turbo dc..
Re: NGK bkr7e-11, bkr7es-11, bkr7e (jBj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj »</TD></TR><TR><TD CLASS="quote">Gonna bump this old thread....
I couldnt get the BKR7E so I got the S-11's for my turbo dc..</TD></TR></TABLE>
BKR7E-11 has a v-grooved(NGK V Power) electrode, BKR7ES-11 does not. Both plugs have otherwise identical specs.
Part Number: bkr7es-11
14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, ISO Length, Projected Tip, .044" (1.1mm) Gap
Part Number: bkr7e-11
14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, ISO Length, Projected Tip, V-Power (V-Grooved Center Electrode), .044" (1.1mm) Gap
Re: NGK bkr7e-11, bkr7es-11, bkr7e (inspyral)
i run straight bkr7-e's in my stock longblock h22....at .25-.28 gap....from what i understand, this is what most stock blockers in the 6-10psi (b or h series) run for best results.
Thanks for the good info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">
Do you think the V-groove makes the plugs that much better? Ive already bought the ES-11 so will probably just gap it to .28 and run it...
Do you think the V-groove makes the plugs that much better? Ive already bought the ES-11 so will probably just gap it to .28 and run it...</TD></TR></TABLE>
I've never run anything other than v-grooved NGK copper plugs, so I really couldn't tell you if there's any real difference between them. The groove is supposed to provide a better spark or something, if I remember the marketing correctly. If you already have a set of non-grooved plugs, you might as well run them and just get the BKR7-E's next time you change plugs.
LOL, The Shodan posts up a chart than any of you could have easily found if you went to the most obvious place. NGK's WEBSITE. most companies have pretty good product descriptions and support right on the web and you would have gotten your answer faster rather than having random people on H-T tell you incorrect part #s
Mac saves the day again
Re: NGK bkr7e-11, bkr7es-11, bkr7e (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">LOL, The Shodan posts up a chart than any of you could have easily found if you went to the most obvious place. NGK's WEBSITE. most companies have pretty good product descriptions and support right on the web and you would have gotten your answer faster rather than having random people on H-T tell you incorrect part #s
Mac saves the day again </TD></TR></TABLE>
Thanks for your helpful and lengthy post
Re: NGK bkr7e-11, bkr7es-11, bkr7e (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">NGK Part Number - #6097 </TD></TR></TABLE>
x 2
x 2
