turbo questions
Old Sep 9, 2005 | 04:59 PM
efHondefender's Avatar
Default turbo questions
how much roundabout whp is a .42 intake .48 exhaust t3/t4 good for on a 4g63. What would the typical trim size be. And how does it compare to, let's say a big 16g.
Old Sep 9, 2005 | 05:18 PM
turboLSvtec030's Avatar
Default Re: turbo questions (efHondefender)
well first of all we call the intake side as u call it the compressor side and the hot side or side that would bolt to the exhaust manifold, the turbine side. typically a t3- t4 consists mostly of an .60ar intake to .63 and a t-3 section turbine of .48 to .58 or so on, theres a lot of combos out there. yours sounds more like a straght t-3 wich is a pretty good find in a junkyard turbo, its capable of around 300 hp with good tuning and alot of patience. when u make a t-3 t4 u use the compressor of the larger t-4 for its larger air displacement and the smaller t-3 turbine exhaust side for the light weight and smaller a/r for quicker spooling on the typical 4 cylinder engine. the tried and true t-3 t-4 with an a-r of. 60 and exhuast a/r of .58 should put out around 450 hp at 14.5 psi.
civichbsi1590
Feb 23, 2011 02:12 PM
beaversdc5
Feb 9, 2008 03:30 PM
BoOsTiN Dc2
Jun 9, 2004 11:24 PM
internet ay
Nov 1, 2002 07:23 AM
Ri5e
Aug 24, 2001 07:59 AM
