anybody have 3 bar map with 550 injectors uberdata map that works
i need a uberdata basemap for ls/vtec with 3 bar map and 550 injectors that works, i have tried to create one and cant get to work for some reason,
Re: anybody have 3 bar map with 550 injectors uberdata map that works (victoriasamantha)
you should go to the uberdata forum and download the latest updated for the 3bar map sensor support and work off that....... it works pretty good.
thanks but does anyone already have a basemap, i am frustrated and dont want to mess nothing up
if u have uberdata 1.7 all u need to do is set the fuel cut to 8. i had problems when i first installed a 3 bar. i thought it was the prgram but the problem was in the wiring of the 3-bar sensor. check ur wiring and just make a basemap for the 550cc's!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victoriasamantha »</TD></TR><TR><TD CLASS="quote">thanks but does anyone already have a basemap, i am frustrated and dont want to mess nothing up</TD></TR></TABLE>
Sorry to be blunt, but with that attitude you shouldn't use Uberdata as your EMS. You will constantly work little things out and it'll be hard, BUT if you put the time and effort in you'll get it to work. Get someone to Neptune/Hondata tune for you is my advice because it seems like you don't want to put the effort in
Re: anybody have 3 bar map with 550 injectors uberdata map that works (adseguy)
i can make u a base map but it wont be in crappy uberdata....switch to crome...i did
first, dont worry about me, i spent hours trying to get uberdata to work, so next time just answer the question Dr. Ruth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victoriasamantha »</TD></TR><TR><TD CLASS="quote">first, dont worry about me, i spent hours trying to get uberdata to work, so next time just answer the question Dr. Ruth</TD></TR></TABLE>
well making a basemap is the least of your worries then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">
well making a basemap is the least of your worries then. </TD></TR></TABLE>
lol
lol
i might get a basemap if you would shut the hell up and mind your business, you must have no life
Banned
if uberdata is giving you woes, perhaps give chrome a try. i just recently switched and i must say load base close loop disable rocks
Re: anybody have 3 bar map with 550 injectors uberdata map that works (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">i can make u a base map but it wont be in crappy uberdata....switch to crome...i did</TD></TR></TABLE>
That is a ridiculous (sp) statement... I tuned 2 cars this weekend. Both had 3 bars, and I used uberdata for one and crome for the other. They worked exactly the same, if you know your way around both programs they work the same. I actually had more problems with cromes ECT function than I did ubers, but that is neglected since they are the same code anyway.
A basemap with a 3bar is difficult, so the only way to run one, with either program is to get it tuned immediately.
Adseguy has a very helpful writeup on how to make a 3bar basemap:
http://uberdata.pgmfi.org/foru...=3494
He's just trying to point you in the right direction.
I know I would trust my own basemap over any other map handed to me over the Internet, but to each his own. Hopefully someone will have a basemap for you.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victoriasamantha »</TD></TR><TR><TD CLASS="quote">i might get a basemap if you would shut the hell up and mind your business, you must have no life </TD></TR></TABLE>
Good luck.
Re: anybody have 3 bar map with 550 injectors uberdata map that works (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
A basemap with a 3bar is difficult, so the only way to run one, with either program is to get it tuned immediately.</TD></TR></TABLE>
whats ridiculous is how uberdata isnt scriptable...and if it wasnt so damn buggy and crash all the time...i might consider trying it again....but crome is simple and straight forward and written very well....
Re: anybody have 3 bar map with 550 injectors uberdata map that works (tilt)
ok, i am sorry, i am frustrated with this car and need to take my time with it, thanks to all who replied and if anybody can help i would be greatful
whats ridiculous is how uberdata isnt scriptable...and if it wasnt so damn buggy and crash all the time...i might consider trying it again....but crome is simple and straight forward and written very well....</TD></TR></TABLE>
Uberdata is scriptable. It has been for over two years ago. Uberdata hardly ever crashes also. The only time ive had problems with uberdata crashing was when I was using a very old POS computer full of spyware. But blame uberdata!
Do you really think you should be offering opinions when you dont have any facts straight? You have a preferance, thats all.
As for the problem, its very simple. Open up uberdata 1.70. Open the stockgsr.bin. Go to the boost tab and press 3bar. Then press file, save as. type in a 3bar.bin. Then press file, open, and open 3bar.bin. Now go into the boost tab and find the fuel cut value. it will say 24. Type in 8. File, save. Then go change your injector sizes and disable your various sensors. This has been covered about 50 times.
Modified by verbripe at 10:13 AM 9/6/2005
You obviously haven't been around or been trying the new releases of uberdata. But honestly this isn't a which is better thread. But you bashing it without any facts is redicuous.
It will be nice if they come out with a version that has everything in it, and is complete. But untill then you just have to know what you are doing with both programs to use them to their peak.
http://artieman.users.sonic.ne...e.bin
basic 3bar turbo bin for ls/vtec with 550cc injectors....like i said i wouldnt boost on it.....drive directly to local tuner....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Its crome BTW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 »</TD></TR><TR><TD CLASS="quote">uber sucks
use chrome</TD></TR></TABLE>
lol, all that coming from the guy that is "untuned" see sig
reactiondc2
08-15-2006 06:59 AM
null.
12-15-2005 06:35 PM
