Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum
My hatch seems to love to bog whenever i'm part-throttling at 10 in. Hg vaccum. It's a slight bog but it's very annoying when you're highway driving. But when i full throttle it's perfectly fine; only happens when i'm driving at 10in. Hg vaccum. Anyone experience this or know more info on a solution? I've posted this in the Hondata forums also. Hm...maybe it needs a good retune..
here's the specs:
Hondata s200b
b18c1 w/ max rev turbo kit boosting @ 10psi.
RC 550s
if you need more info, leave a reply.
Modified by mRek9R at 3:58 PM 9/4/2005
Modified by mRek9R at 11:53 PM 9/4/2005
here's the specs:
Hondata s200b
RC 550s
Re: Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum (mRek9R)
yeah its most likely the tune if its an s200 box. unless whoever tuned it ran an old rom editor version....
Re: Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum (Mase)
check your tps voltage. I had the same problem. I tried to retune it still had a hesitation. Went to hondalogger checked the tps, moved the voltage to a little more than a half .56v. Evertything cleared up. However, Ihad a str throttle body and I had switch the tps sensor. Maybe hard throttle moved it a bit. I also thought it was a bad trans, but it wasn't. Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">yeah its most likely the tune if its an s200 box. unless whoever tuned it ran an old rom editor version....</TD></TR></TABLE>
the previous owner said something about a reflash...do you happen to know about that? Thanks, 8)
Re: Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum (22psicrx)
COOL! i'll check that tomorrow morning then! thanks! 8) bump for more solutions! 8)
Re: Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum (nickromeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo »</TD></TR><TR><TD CLASS="quote">is closed loop enabled?</TD></TR></TABLE>
nope, thanks! bump for more answers! 8)
Re: Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">my car is doin the same thing, but id imagine its the tune, jus thavent had time to get it checked out</TD></TR></TABLE>
k, if you retune anytime soon and resolve the issue let me know! 8)...i probably wont retune mine till later this year since college starts tomorrow, gonna be busy busy busy with homework. 8)
chewyv
Engine Management and Tuning
04-17-2017 07:19 PM
importboi22
08-09-2005 08:15 PM
