SAFC Tuning Problems
Old Sep 8, 2005 | 02:29 PM
94ta_lt1's Avatar
Default SAFC Tuning Problems
I have a 93 del sol with a d15b7. I am running a tubular header and t25 turbo. I put the dsm injectors in it with the resistors in line and have been using the safc hack for tuning. I just put a wideband O2 in the car and wanted to get the tune fixed. It is running very lean at higher rpms(about 14:1). When i try to lessen the correction precent for -30 to about -25%, the car starts throwing codes and won't run right. I can run it under 4k with the corrected % but as soon as i take it to red line, the check engine goes off and the car will not idle. Someone told me i needed to install a check valve in something but i'm not sure. I am running 8 lbs of boost. Can anyone help me figure out whats wrong? Thanks
Old Sep 8, 2005 | 02:39 PM
93turbo16's Avatar
yea, for soem reason it seems you injectors aren't flowing or maybe your fuel pump or fuel filter is bad.
Ever think of running uber or crome. Simplifies this.
But my bet is on bad fuel pump or filter. The reason you are throwing the code is because the afc acts like a check valve, since you take some much percent out of the map voltage it makes the ecu think it is actually in vacuum not boost, but the bigger injectors still give it the right fuel.
Old Sep 8, 2005 | 02:58 PM
94ta_lt1's Avatar
Default Re: (93turbo16)
I put a brand new filter on it when i did the turbo set up. So when i change the full throtle values from -35 to -30, your saying this causes the computer of the car to read it differently? At the time the turbo was done, i used the safc b/c it seemed to work well on other cars and was the cheapest route. The car is just a daily driver car and i had the turbo left over from upgrading the one on my 2g gsx so i decided to fab up a header for it. Why would it be a bad fuel pump? Just seems like it needs to be tuned richer on the top end but tuning it sets off the check engine.
Old Sep 8, 2005 | 03:04 PM
93turbo16's Avatar
Right, but I wouldn't add a check valve on top of the mix. If you would want, the best way really is to switch to uber or crome and get it tuned.
Old Sep 8, 2005 | 03:07 PM
94ta_lt1's Avatar
Yeah but how much would it cost to switch?
Old Sep 8, 2005 | 03:08 PM
94ta_lt1's Avatar
Default Re: (94ta_lt1)
And would switching over mean i would have to use different injectors and go back and remove the resistors?
Old Sep 8, 2005 | 03:12 PM
93turbo16's Avatar
nope same resistors and more than likely the same ecu. I pmed you and also Imed you. We can talk about it.
Old Sep 8, 2005 | 03:16 PM
94ta_lt1's Avatar
Alright, i'm not on my home comp. right now so that AIM woun't work...or i can actually catch you on aim later when i get home
94ta_lt1
Aug 14, 2005 08:35 AM
SOHC_MShue
Apr 27, 2005 05:29 AM
sleeperek
29
Mar 10, 2005 03:50 PM
blkDOHCsol
Feb 13, 2002 08:24 PM
