driving w/out charge piping.
Location: home of Marciano/Haggler, city of champions, MA
i'm going to need new charge piping ( from turbo to intercooler) is it ok to drive like this. it wont throw off my a/f as long as i dont go past like 4k rpm right?
Re: driving w/out charge piping. (h22boy)
I believe you can 'over spin' your turbo by doing this.. in which case it would get f*cked up. You might want to look into an alternative before trying.
::edit::
I just found this
https://honda-tech.com/zerothread?id=661694
::edit::
I just found this
just lay off the throttle.....how hard is that for people. just don't get past 50% throttle...period. You'll be fine if you stick to that
Re: driving w/out charge piping. (adseguy)
My suggestion: unbolt the center section of your turbo from your turbine housing. Hack up a piece of thicker metal to fit over the 6-bolt flange on the turbine housing. A bit of leaking should be okay short-term, and almost no chance of melting that block-off plate even if it's thin due to N/A opperation.
The other option would be to highly restrict the outlet on the compressor housing. Not enough to cause compressor surge, just to somewhat simulate having to pressurize the tubes/fmic/motor.
Either that, or risk it. Regardless, open up the wastegate all the way.
go to home depot and buy some pvc piping and construct your own "temporary" charge pipes i guess? thats what i was planning on doing.
Re: driving w/out charge piping. (jdmzintegra)
yeah just lay off the throttle. just stay outta boost. i drove to the exhaust shop with no downpipe on the turbo. shrugs
I used to blow off my charge pipe hose almost weekly. I would just drive like a granny untill I could put it back on. I have since rebuilt the charge pipe and added reinforced silicone hose and t-bolt clamps now it does not do it.
Re: driving w/out charge piping. (200cs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200cs »</TD></TR><TR><TD CLASS="quote">I used to blow off my charge pipe hose almost weekly. I would just drive like a granny untill I could put it back on. I have since rebuilt the charge pipe and added reinforced silicone hose and t-bolt clamps now it does not do it.</TD></TR></TABLE>
Same here, but i think i've actually overspun my first turbo. It like it pop off at the track mid run while i'm in the high rpms and its too late to just lay off. That baby started drippin out out the bottom eventually, it was sexy. I would suggest not drivin on it or contstruct some temporary ish.
turbotypeR@SPEC
12-14-2003 03:57 PM
