Spooling performance Downpipe
Old Sep 6, 2005 | 03:50 PM
brent_G's Avatar
Default Spooling performance Downpipe
Well i have a spooling performance downpipe for my t3. Its the 3 bolt flange ... But i can only get a bolt into 2 outta the 3 holes. The bend is too sharp to get the 3rd bolt in.
Anyone else have this problem?
i was gonna try and run a bolt from the bottome but its not enough room to get a bolt all the way thru to put a nut on.
Any advice would be nice.
Old Sep 6, 2005 | 04:06 PM
brent_G's Avatar
Default Re: Spooling performance Downpipe (brent_G)
well thinking about it. Its prolly designed to be used with the stock original studs that are supposed to be in the turbo o2 housing.
Mine are gone. So i was using bolts to fasten it down. So i assume thats the problem.
Old Sep 6, 2005 | 04:53 PM
project dc2's Avatar
1 question
who did you buy my downpipe from and whats your setup.
p.s, just cuz it has the same bolt pattern doesnt mean itll fit your manifold.
if you pull 5 jelly beans from a jar. they may look alike... but are they EXACTLY the same in every angle in every which way direction shape or form. are their dimensions a dead on clone of each other?
take it as this...
drag downpipes dont fit revhard manifolds
neukin downpipes dont fit fullrace manifolds
spoolin manifodls ... dont fit .. any manifold you stick it on unless its what i made it for.
bottom line is .. downpipes are in most cases NOT interchangable even if they have the correct flange unless its a mass produce item that is made 100% the same like the last one over and over again .
if that downpipe. was made for a HF manifold with a *custom* adapter plate. which im pretty sure which downpipe you probably have
its not gonna fit an HF manifold with say .. a BMC or other brand adapter plates becasue they have diffrent angles. shapes. dimensions and thicknesses.
Old Sep 6, 2005 | 04:59 PM
brent_G's Avatar
Default Re: Spooling performance Downpipe (project dc2)
What i was trying to explain was attaching the downpipe to the turbo.
There is 3 bolts holding it to the turbo.
On the inside bolt of the downpipe the bend is too much so you cant fit a bolt in there with out it hitting the downpipe (to attach it to the turbo)
if my camera was working id take a pic and it was explain it better..
Old Sep 6, 2005 | 05:19 PM
mbdelsol's Avatar
will a stud and nut work??
Old Sep 6, 2005 | 05:25 PM
brent_G's Avatar
Default Re: Spooling performance Downpipe (mbdelsol)
Yeah thats what i was plannin on doing. I just figured when they designed the downpipe they designed it with the stock studs inplace. So it should be an easy fix. Ill post pics to show ya what i mean tho..
Old Sep 6, 2005 | 05:28 PM
brent_G's Avatar
Modified by brent_G at 10:22 PM 9/6/2005
Old Sep 6, 2005 | 06:16 PM
norcalcrx's Avatar
You need to put a stud on that one hole.
Old Sep 6, 2005 | 06:21 PM
brent_G's Avatar
Default Re: Spooling performance Downpipe (norcalcrx)
yeah i just did... now its ready to go.
Old Sep 6, 2005 | 07:28 PM
yea its meant to be used with a stud and nut. u bought that frmo .. 98gsr or something like that right ?
Old Sep 6, 2005 | 07:45 PM
ATS*Mark's Avatar
OG triple OG
SP has some good **** , enjoy that downpipe. at least you didnt have to go through phil touching your *** while he welds , hes a little gay.
Old Sep 6, 2005 | 08:12 PM
brent_G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> yea its meant to be used with a stud and nut. u bought that frmo .. 98gsr or something like that right ? </TD></TR></TABLE>
Yup.
It was still a lil hard getting the nut on. I had to hold the flange away from the turbo and slowly screw the nut on as i let it go down.
Other then that the downpipe looks amazing!
Old Sep 6, 2005 | 08:24 PM
Quad-Damag's Avatar
Default Re: Spooling performance Downpipe (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">SP has some good **** , enjoy that downpipe. at least you didnt have to go through phil touching your *** while he welds , hes a little gay.</TD></TR></TABLE>
u act like u didn't like it
Old Sep 6, 2005 | 08:34 PM
Deluzional's Avatar
Default Re: Spooling performance Downpipe (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">u act like u didn't like it</TD></TR></TABLE>
what are you talking about..you cant keep your hands off him...dont be jealous
Old Sep 6, 2005 | 08:38 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Spooling performance Downpipe (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">what are you talking about..you cant keep your hands off him...dont be jealous </TD></TR></TABLE>
muahaahhaahh
Old Sep 6, 2005 | 09:17 PM
since when did i cater my products to a bunch of homosexuals ? err maybe they came in straight and went out walkin a lil crooked... gettin them to the dark side one by one.
Old Sep 6, 2005 | 09:24 PM
Quad-Damag's Avatar
haha
fucken mark
Spoolin
Old Sep 7, 2005 | 06:01 AM
ATS*Mark's Avatar
OG triple OG
ahhahaaha
phil , remember when you told me to open my mouth and hold a pose while you were doing my exhaust . i didnt understand why untill i got home , then it got real cold all of a sudden.
Old Sep 8, 2005 | 01:48 PM
yee SERIOUS's Avatar
^^^ now that is disturbing......
Old Sep 8, 2005 | 03:19 PM
SDT Project EF's Avatar
Default Re: (LiTtOGPiMp)
at least he wasn't ruff with you.
Speed94
Aug 1, 2008 06:35 AM
$ISELLTOU4LESS$
Feb 11, 2007 11:12 AM
project dc2
Jun 5, 2004 12:53 AM
