Aem and wideband..using 30-1000 on obd2
I am trying to help a friend wire a wideband to aem 30-1000 which is for obd1 on his obd2 ...he has conversion harness...and I was just wondering do I wire up the analog output wire to d14 on conversion harness or to what ever the o2#1 is on obd2 original harness...I have it to d14 right now and aem is so far off that adjusting the gain by +/- 2.00 wouldnt even help? Thanks for your help
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Re: Aem and wideband..using 30-1000 on obd2 (mchuang)
it should be just fine in d14. just make sure u solder the connection and ground to the battery...what color wire do u have in d14?
its a harness so they are all black and im using a24 for analog ground... but im just wondering should i tap into my stock harness rather than the conversion harness
Re: (mchuang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang »</TD></TR><TR><TD CLASS="quote">its a harness so they are all black and im using a24 for analog ground... but im just wondering should i tap into my stock harness rather than the conversion harness </TD></TR></TABLE>
i ment what color from your wide band harness.....try grounding directly to the battery..and are all your connections solderd?..it shouldnt matter if u tap into the factory harness or conversion harness..
thekidyayo
07-01-2008 06:05 PM
CHEFH22HATCH
08-30-2007 09:48 AM
morepoop4u
08-22-2002 01:27 AM
