Oil return for Greddy 19T SOHC turbo.....
I am essentially piecing together my Greddy kit and am down to the last few parts. I need to know what I can do for the oil return flange that goes to the oil pan. I have the flange for the turbo already and the line. I know the Greddy kits come with elbows, but obviously I don't have one or the ability to get one locally. What other options have people used? Find a chunk of tubing the correct diameter, bend, weld?
Re: Oil return for Greddy 19T SOHC turbo..... (Hybrid93Eg)
You can get a barb fitting and install it, or you can weld a piece of pipe and use that. Check if your oil pan is aluminum or steel before welding
Home depot plumbing section has barb fittings. I use 3/8 male thread to 1/2" barb for -10 drain lines, but you could use 1/2 male thread also.
On the pipe welding situation, if you are using a -10 drain line you will want a 5/8 O.D. pipe as the -10 I.D. is 5/8.
B16Civic93
06-16-2005 03:53 PM
